Hello everyone, it's been a while since I've been here and I have new projects to share with all of you. Lately, I've been working on a shell called xFiles CE. This shell is an improvement (and port, ish) from the monochrome predecessors of xFiles and xFiles 2 for the TI-83/84/+/SE series calculators. An image below is an example of the polished Dialog box which will be used in the program.
I plan to pack this program full of features, including ones that haven't been included in xFiles. A small list of some features I'll include in the program:
- Safety Mode: When enabled, this mode will prevent xFiles CE from running assembly programs, copying, editing, deleting any programs. It will also prevent xFiles from running when the battery level is less than 3 (that last part is a pending idea).
- PIN protection: A security measure that will prevent unauthorized access. xFiles CE will be protected by an encrypted 4-digit PIN and will lock out the program for a certain amount of time if a certain amount of attempts has been reached.
- File Rename: The ability to rename any program or app variable.
- Revision check: Checks if your calculator is Revision M+ or not.
- Battery Charge indicator
- UI theming
- Custom backgrounds
xFiles CE will have an improved and clean user interface, with more space to place information and text in. It will also include a custom font (separate program) to make everything look a little snazzier.
This program will be a shell written in TI-BASIC with the aid of assembly programs to enhance your experience. More features will be added along the way as this is in heavy development. I am looking to release a beta of this program by mid-late December, so look out for it! This will be my first working shell for the CE. Once Celtic CE beta 2 is out, I will speed up development progress.
There will be some things in xFiles CE that will be a bit of a "downgrade" compared to it's monochrome versions, but I won't be able to fix these due to the limitations of Celtic CSE compatibility. I Won't be able to copy files multiple lines at a time due to the limitations of Celtic. Only one line can be copied at a time. Some functions will look messy because of how Celtic CE operates.
Estimated Requirements:
- TI-84 Plus CE/T/Python Edition Series Calculators
- OS <= 5.4.0
Memory Requirements:
- 10K of RAM
- 20K of flash storage
Let me know what you think of this! This will be a fancy BASIC shell, so it obviously won't be as good as existing ones. If there are any features or ideas you have for this program, let me know! Ideas, suggestions, comments, constructive criticism is appreciated!
On a side note, I do not identify as BioHazard anymore. I am the same person you all know and hate, so I would appreciate it if you refer to me as AchakTheFurry, or simply Achak. Thank you!
- UI theming
- OS <= 5.4.0
- 10K of RAM
