- It's finished!
- 22 May 2020 05:18:35 pm
- Last edited by TheLastMillennial on 05 Jun 2020 10:17:01 am; edited 2 times in total
Great news everyone! I've fixed the USB port and completed the project!
Second Battery Updates:
Not a whole lot here has changed, the main difference is I've used Kapton tape to isolate it from the PCB and I've covered the battery contacts in tape. I've also secured it to the PCB so it doesn't jiggle around at all.
Wireless Charging Updates:
I've basically redone everything on the inside and did it right this time. I received a wide variety of soldering iron tips which made soldering in such tight places much easier! Who knew that the right tools would make a job much better? 😄
First, I de-soldered the wires from the USB port and cleaned up the connections. I made certain there were no shorts in the port then I plugged it into my computer. Voila! I've never been happier to see TI Connect CE bring up my calculator's contents! I immediately backed up all the files on the calculator and ran a USB self test which it passed with flying colors!
(As usual, click for full size)
I'm still unsure why the USB port didn't work even if unconnected wires were on it, but I'm just glad it's fixed now. I then soldered the wireless charging leads to the charging station contacts at the bottom of the calculator which I should have done in the first place! Finally, I wrapped everything up in Kapton tape and I closed up the calculator. Fortunately, it works even better than new! The wireless charger works, so does the second battery, and the USB port is fixed.
There is something a bit odd with the wireless charger. For some reason when I put it on my new charging pad it makes the pad emit noises like chirping or sometimes a tone. It's not very high pitched which is what confuses me. It doesn't make any noise at all when I put just my iPhone on it. My best guess is maybe the receiver inside the calculator is too far away since the charging pad didn't emit noise when I was testing the receiver outside the shell. The only negative effect I've noticed is the charging pad and the shell of the calculator are warm where the coils are. The temperatures aren't even close to alarming though.
Backlighting Keys Update:
I think I'm going to hold off on this one for now. It appears that I just can't find small LEDs out there that are bright enough without drawing a ton of amperage. Even if the batteries can handle the load, I'm not sure I'm comfortable with how much they heated up during my tests. That's not to say I'll never come back to this again, I'll just have to look deeper, or get a 3D Printer to create thinner keys (which is more likely to happen).
Conclusion:
Unless there's something drastically wrong with with what I've done, I'm going to call this project complete. Would I recommend doing any of these mods yourself? I'd say no to double batteries due to the risk of something going drastically wrong. However, the wireless charging mod actually isn't dangerous if you do it the right way. All you need to do is cut away the shell to make room for it, secure it to the back shell, and solder the leads to the charging station contacts which hardly anyone here uses anyways. I may even do it to my own revision M CE. I had a lot of fun with this project, even if I got scared to death last post. I'm looking forward to trying more modifications in the future!
Conclusion:
