I recently got my hands on the TI-80 VSC, completing my collection of the TI-8x series (though not all variants, just one of each number). Here's the teardown I performed.
ROM 4.0. As usual, we observe ribbon cable degradation. Good thing it doesn't affect the VSC panel output.
April 1995, Revision B. The Revision A VSC remains elusive as of posting.
Side profile, note that the bulkier housing prevents the slide cover from going on the back.
The VSC port.
Opens up like a book. Quite reminiscent of opening an iPhone: one could tear the ribbon cable if they didn't know where it is.
Close-up of the electronics. T6M53A ASIC, as expected.
Display assembly. In the middle, the LCD driver circuit on a thin and delicate boad.
The VSC daughterboard.
VSC board and connector. Rather than pulling the cable straight out, I found it helpful to use a gentle wiggling motion to ease it out.
Reverse side of the VSC board.
Rear housing.
The keypad matrix and LCD.
Front panel.
Personal opinion: Despite the shortcomings of the TI-80 as a budget calculator, the compact design and effort TI put into keeping costs down are quite admirable, especially the choice of a proprietary ASIC. I imagine that the TI-84+CE could learn from the TI-80 with optimized hardware, compact size, and low cost. But I digress.
Full album: https://imgur.com/a/fWpP3KR and https://imgur.com/a/RKmZvHi
Ideally, these would be a bit less grainy as it is my first real experience with the DSLR camera.
Photos with the VSC panel when I get some more downtime. Kind of comical watching the whole setup being powered off two coin cells, if one so desires.
And the Ti-Graph Link software for the TI-80: https://tiplanet.org/forum/archives_voir.php?id=2786234
It comes on a 720k floppy and only does screenshots.
The VSC port.
Rear housing.
Front panel.
