Whenever I run the install_tilp script it gives me this error:
/bin/sh: line 3: syntax error near unexpected token `('
/bin/sh: line 3: `int main(int argc, char * argv[]) {'
/usr/bin/ld: /usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0/../../../../lib/Scrt1.o: in function `_start':
(.text+0x24): undefined reference to `main'
collect2: error: ld returned 1 exit status
any ideas?
Tilp is directly in the aur as aur/tilp. Not sure why you would want to run the install script ? Anyway, it seems it fails to compile for whatever reason.
But the aur package gives me this error:
==> ERROR: Could not resolve all dependencies.
:: Packages failed to build: libticables-1.3.5-2 libticonv-1.1.5-1 libtifiles-1.1.7-1 libticalcs-1.1.9-1 tilp-1.18-1
You need to seperately install libticables, libticonv, etc.
An easier way would be to install the yay aur helper:
git clone https://aur.archlinux.org/yay.git
cd yay
makepkg -si
Then just type:
yay -S tilp
It should automatically clone and compile the missing dependencies.
cd yay
makepkg -si
Then just type:
yay -S tilp
Of course I use yay
For instance, compiling an up to date version ? The TILP II 1.18 release and associated libti* versions are pretty outdated by now. Yes, it's my fault.
reesericci: a shell or C compile failure on "int main(int argc, char * argv[]) {" is very unusual and unexpected Smile
How are you running install_tilp.sh ? It contains a shebang, as all well-behaved shell scripts do, so it can be run by:
* ./install_tilp.sh from the same directory, a relative path or an absolute path, after using chmod +x on the file;
* bash install_tilp.sh, again with -
Put another way, do not use commands of the `sh install_tilp.sh` form. Your sh might not be bash - it isn't on Debian, for instance.
cd yay
makepkg -si
Then just type:
yay -S tilp
Yay is deprecated. Do not use or recommend the usage of yay. Instead, install paru, the official successor to yay made by the same developers as yay.
yay -R yay
sudo pacman -S --needed base-devel
git clone https://aur.archlinux.org/paru.git
cd paru
makepkg -si
paru -S tilp
It should automatically build tilp and any dependencies.
At the very least, don't use tilp, use tilp-git, since the AUR has such a package. But the correct thing to do is to use the official install script for libti*/gfm/tilp.
You mean install_tilp.sh from the Tilp website? If so, I was getting errors when using it. See 1st post in this thread.
Sure, I mean https://ti-pla.net/tilpinst . I replied above, but you didn't yet provide the information I needed to try and understand what's going on, which, of course, may simply be caused by the fact that you hadn't seen my reply or haven't yet had time to reply Smile
cd yay
makepkg -si
Then just type:
yay -S tilp
yay -R yay
cd paru
makepkg -si
paru -S tilp
I use paru, but I reference yay because thats what people know
Is there an AppImage for tilp? My AUR broke recently...
You can install from git: https://github.com/debrouxl/tilp_and_gfm
And the install script is https://ti-pla.net/tilpinst .
