Hi, I asked my question on stack overflow. I was wondering if you could help: https://stackoverflow.com/questions/63320698/when-using-z80-asm-is-there-a-difference-between-hl-and-bc-de
Confusingly, a register pair on the eZ80 is 24-bytes but each lone register (A, B, C, D, E, H, L) is 8 bits. It is not possible to write to the upper byte of the register pair using the 8-bit registers.
To solve your problem you have two options.
Using the stack to copy HL into DE.
Or exchange values of HL with DE.
push hl
pop de
ex de, hl
On the ez80 in ADL=1 mode the register pairs are '24-bit', consisting of 3 x 8-bit portions if you will.
SavesScreen = 0D0EA1Fh so when you load that in HL the 'upper' byte contains 'D0'. You also set DE=2 or 000002, which means that '00' is in the DE upper byte.
As Brando mentioned an 8-bit register assignment like LD D,H \ LD E,L then you aren't altering these 'upper' bytes and your resultant address in DE = 00EA1F.
You can relplace the register assignment with PUSH HL \ POP DE as Brando suggested and this will have the desired effect.
What would be the best way to get those 24 bits into a specific memory location? The best I can think of right now is push the value onto the stack and then using the stack pointer to get 1 byte at a time. Is there a better way?
You can use ld (address),hl to store the three bytes of hl to a memory address. This also works for the other 24-bit registers.
Oh that was you who asked that question!
Are you looking for something like:
ld (address),hl ; store HL in little-endian at address
ld hl,(address) ; read the 3-byte value at address into HL
