- TI-80 Hardware Revisions and ViewScreenification™
- 02 Jan 2019 03:54:51 pm
- Last edited by mr womp womp on 23 Nov 2024 08:46:28 pm; edited 16 times in total
EDIT: This post assumes there are way less revisions than there actually are, for a more complete list, see this post
I have been working my way up the tree of TI graphing calculator knowledge for a few years now and have arrived at the TI-80 branch. Unlike many other branches on this tree such as the TI-82, this branch has gotten no love for the last 25 years, and its about time somebody actually cared about it a little. I have gathered a bunch of TI-80s and in doing so, I hope to add a couple leaves to the branch.
The TI-80 has 3 hardware revisions (A, B and C).All viewscreen models found to date have had revision C, however, TI has been known to turn very early production models into viewscreens Therefore, it is expected that revisions A and B should also exist as viewscreen variants, but this has not been observed as of now.
EDIT: Zeroko has a viewscreen variant of a revision B.
Here is the information regarding production dates of the 3 known revisions for the non-viewscreen variant:
When it comes to the ROM revisions, only 2 are known, 3.0 which is paired with hardware revision A, and 4.0, which is found in the two other revisions. ROM revisions 1.0 and 2.0 have never been observed, and are assumed to not exist in mass production.
Interestingly, 32kb of the usable code of the ROM is contained in the ROM chip, and 16kb is contained in the ASIC, both of which are proprietary. Back in 2010 and 2011, some crazy attempts by Critor had led to 97% of ROM 4.0 and 66.7% of ROM 3.0 being dumped by soldering the ROM chip onto an EPROM programmer to get the contents of the ROM chip, and making the calculator display the contents of its memory on the screen to get the section stored on the T6M53A proprietary CPU. All these attempts were scrapped because Randy Compton (TI-Planet member) managed to write an ASM program to transfer the contents of the ROM from the jack on a viewscreen model. She was able to dump the entire ROM and subsequently create a TI-80 emulator.This has not been done with ROM 3.0 yet, but doing this would require a viewscreen model with hardware revision A since this is the only version that has ROM 3.0, however this has not been spotted and is only assumed to exist.
EDIT: It has been done now... currently, a viewscreen revision A still hasn't been spotted, but the ROM was dumped by coercing the calculator into displaying its ROM contents to the screen then manually transcribing the tokens and converting them back into bytes (since OCR has been largely unsuccessful because of the small screen with bad contrast and a smaller font).
The main board for the non-viewscreen and viewscreen models is the same except that the communication circuit is not populated on the non-viewscreen model, and the jack is of course removed. Therefore, I have no reason to believe someone couldn't manually transfer the components from a donor viewscreen onto a non-viewscreen with ROM 3.0, effectively turning it into a franken-viewscreen. Such a calculator could then in theory be dumped using the same method used for ROM 4.0, resulting in a dump of ROM 3.0. Of course, this would require sacrificing a viewscreen TI-80, which is strikingly rare just for a chance at dumping 3.0.
I own multiple of each revision, along with the latest known one, therefore, I decided to document the hardware.
Here is a picture containing the 4 calculators.
[img]https://i.imgur.com/iqowmfhl.jpg?1[/img]
(top left→I-1000C, top right→I-0595B, bottom left→I-0695C, bottom right→I-0495A)
Last night, me and CVSoft/notipa sat down on HCWP to document revisions A through C.
In total, I took apart 4 calculators (one for each revision and the one from 1000 since it is significantly newer than the others)
All 4 had T6A79 display drivers, and a change in the display driver revision does not seem to constitute a large enough change to warrant a hardware revision change, because multiple different display driver revisions have been observed within the same hardware revisions.
Here are the results of what was observed in each calculator.
It is important to note that the datecodes on the ROM, CPU and board are in YY/WW format, while the one on the back of the calculator is in MM/YY format.
On August 14th 2016, an ifixit tutorial about replacing a TI-80's motherboard and screen was discovered by Adriweb. It had been posted in early 2015. The images were not of high enough quality to make out the numbers on the chips, but the board number (TIAPLMB-31G) could be seen quite clearly. Here is the best image from the video:
That board number had not been spotted before and remained a mystery for a few years, but as it turns out, my latest TI-80 (the last one in the list of components) has that exact board number. Taking it apart, I did not notice any difference aside from the board number itself and the type of screws used.
Between revisions A and B, the CPU changed from a Toshiba T6M53 to a T6M53A. The ROM revision changed from 3.0 to 4.0 and the ROM chip went from LH5359NK to LH5359NN.
Between revisions B and C, the ROM chip went from LH5359NN to LH5359NN-80, and the board number changed from APLMB-30F to APLMB-30F 2-1. APLMB-30F-A2-4 has also been spotted in another revision C.
Between early and late revision C, the screws on the outside of the case changed from cross head screws to torx head screws. Inside, only the board number appears to have changed to TIAPLMB-31G.
- Revision A was produced between January 1995 and April 1995, with the vast majority being produced after February.
Revision B was produced only during May 1995. It is not know whether there are some 'A's and 'C's that overlap into the month of May, but none have been found.
Revision C was produced from June 1995 until the end of production in late 2000, with the latest known one being manufactured in October 2000
Factory: I
Datecode: 0495
Hardware Revision: A
ROM: 3.0
LCD Driver Version: 5B
CPU: T6M53
CPU Datecode: 9505H
MB: APLMB-30F
ROM: LH5359NK
ROM Datecode: 9504D
RAM: SRM2264LM10 F4Y1 129
Board Datecode: 9512
Factory: I
Datecode: 0595
Hardware Revision: B
ROM: 4.0
LCD Driver Version: 5D
CPU: T6M53A
CPU Datecode: 9515H
MB: APLMB-30F
ROM: LH5359NN
ROM Datecode:9510D
RAM: SRM2264LM10 F541 236
Factory: I
Datecode: 0695
Hardware Revision: C
ROM: 4.0
CPU: T6M53A
CPU Datecode: 9516H
MB: APLMB-30F 2-1
ROM: LH5359NN-80
ROM Datecode: 9516D
RAM: SRM2264LM10 F541 153
Board Datecode: 9509
Factory: I
Datecode: 1000
ROM: 4.0
LCD Driver Version: 0E
CPU: T6M53A
CPU Datecode: 0002
MB: TIAPLMB-31G
ROM: LH5359NN-80
ROM Datecode: 0008D
RAM: SRM2264LM10 F00212437
Board Datecode: 0015It is important to note that the datecodes on the ROM, CPU and board are in YY/WW format, while the one on the back of the calculator is in MM/YY format.
