- BCEDF (ebook reader)[TI-84+CE]
- 27 Mar 2019 04:38:18 pm
- Last edited by beckadamtheinventor on 27 Mar 2019 05:24:14 pm; edited 2 times in total
Over the last couple of days, I have been working on an ebook reader for the TI-84+CE, written in ICE.
It is nearly complete, and includes these features:
It will have these additional features upon release:
This program is built to be called as a subroutine from a prgm, and can be run as a BASIC program.
DO NOT try to edit, however. Most of the data is unreadable in the editor.
Use the converter, which will be released with the reader.
I have also written a converter, in python 3, which converts text (riddled with escape codes, however) into this format, and outputting a ".8xp" file. It can be called from the command line, or run on it's own.
This is still a WIP, but do expect a release within the next seven days.
Screenshot of a test document, converted with the converter:
EDIT:
Lorem Ipsum text from www.lipsum.com, stress testing the program. Note that it scrolls between line-breaks, not lines. The time in the menu was the entire loading time, to load approximately 31Kb of text.
text size
text color
text highlighting
underlining
Tabs (which can also be used to support a multi-collumn layout/table)
custom text characters
sprite characters
external images (alligned left, center, or right)
custom background/foreground colors
horizontal bar
'links' to jump to other lines upon clicking
'links' to jump to another document's at a line
EDIT:
