- Adriweb
- Super-Expert (Posts: 773)
- 17 Feb 2019 10:44:32 am
- Last edited by Adriweb on 17 Feb 2019 11:03:36 am; edited 1 time in total
Actually it's (secretly) aperating even better with another calc:
(all credits to jacobly, I was just testing on the 83PCE)
Mateo found a way to overwrite the boot code, but doesn't want to share any more info because it could be used to permanently brick calcs.
This is significant because a custom bootcode would allow you to install a custom operating system or use custom interrupt handlers.
It's also dangerous because the bootcode is what allows you to reinstall the OS, and there is no way to change the bootcode if the bootcode is not working properly. This means that if you break the bootcode, the calculator is permanently unusable unless the flash chip is replaced.
I though boot code was read-only or something and was impossible to change? How do you even go about overwriting something that's designed not to be overwritten?
Also, why Are there random characters like the | and H next to the ... ?
Great job Mateo and Jacobly! I can't wait to have FreeOS on the new calcs!
MateoConLechuga wrote:
Basically magic but using code.
Sounds more like black magic. Good luck with the custom OS because everything TI makes is kinda trash.
