Okay, I've really been getting into making little C++ and QuickBasic games lately, but I've always wanted to make an online one. How difficult is this? If I have a variable in C++ and know the exact IP address of the other computer, how complicated would it be to send the variable to the other computer?
I've never used any 'standard' c++ networking libs, but you should use sockets for this (there is a standard sockets.h i think, but i've only used em thru python and wxWidgets)
try searching for c++ sockets (or even just C sockets, as C code can be used in C++ just fine)
generally tho, you create a new socket object, call its connect function (this is where you'll have the other comps IP and Port) - it MUST be listening for connections! (socketServer object). Then, once the connection is established, you just call a send(variable) on the client (or server) and a recv(variable) on the server (or client)
sockets are dumb however, so you could send an int (which is 4 bytes usually) and then do a recv with a char (which is 1 byte) and it will have no problems with that - you could actually do 4 char receives, as its just stored byte-for-byte, no header info or anything like that
Sorry I can't give you better info tho, its been awile since I've used sockets in C/C++
Thanks. I had no idea how to even get started. I try to find out programming stuff myself but I had no clue what to even type for a google search.
Wikipedia has gotten mature enough that I find it easier to get information there than Google -- give it a whirl.
Just in case:
http://en.wikipedia.org/wiki/sockets
Just in case:
* http://en.wikipedia.org/wiki/Berkeley_sockets
I didn't actually check it; I just typed http://en.wikipedia.org/wiki/topicname
Now the page exists.
Did you just creat it? Incase you didn't notice, http://en.wikipedia.org/wiki/Socket already exists and covers everything much better
Just in case it didn't say in the Wiki article (I didn't check), to use sockets with windows in C++, you need to use winsock.h. You might have to make a server program to handle additional players (depending on the style of online game you're making). I'd try finding a good winsock tutorial to get started. MSDN has their usual technical crap, but it'll really help you understand the function syntaxes.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/winsock/winsock/windows_sockets_start_page_2.asp
I started working on a socket class awhile back, but never finished it. I should get it done...
Hmmm, this is exactly the kind of stuff I'll/other people will need to know for the gCn programs. Ty, Jincs.
[quote="JincS"]Just in case it didn't say in the Wiki article (I didn't check), to use sockets with windows in C++, you need to use winsock.h.quote]
I believe you can still use the standard socket.h file in windows too, which follows the "standard" berkley socket API, although admittedly I haven't ever done socket programming directly, and instead went through Python or wxWidgets...
No, Python has built in socket support. No need to learn the specific quirks of each OS's socket interface
Oh, reallly? Even better! So I guess Python has some advantages over lower-level OOPs.
here is a list of the standard, bundled modules http://docs.python.org/modindex.html
As you can see it is quite extensive, even including a GUI API (tkinter), various networking stuff (from low level sockets to one-command opening of a website using urllib), sound, various os and system functions, all sorts of stuff
Python has alot of advantages over lower-level languages, or even against other high level langs like Perl or VB.
/me reads....wow, that is quite impressive. Perhaps I should consider learning Python more thoroughly myself...
Good point Kllrnohj: Berkely Sockets should work with Windows, and I would recommend it (just 'cause I don't like winsock).
But, if you do end up using winsock, DON'T use ANY of the WSA___() functions, or you'll screw yourself out of portability (and a good program). The rest of them should port quite smoothly to other OSs.
My Sockets Class is almost done for winsock...I'll post a link when I'm happy with it and have tested it. Then I'll make a Berkely port of it.
» Goto page 1, 2 Next
Page 1 of 2
