I've started to learn C for 68k calculators, but for some reason when I tried to send a file from TIGCC to TiEmu, TIGCC got mad and said that TiEmu is not running. If anybody could help me, I'd appreciate it!
Did you try running as admin?
Issue of sending the file was solved in SAX, apparently, I didn't point to where TIGCC should look for TiEmu
. In this process, I upgraded to the GCC4TI IDE.
The issue now is, the file won't run when I send it. It even automatically types in the program name for me and runs it, but it won't actually run. Help please?
EDIT: I reset the emulator, and now it works. Troubleshooting++
Good to see that this is solved
Did you upgrade just the IDE, or the whole development environment, to GCC4TI ?
I upgraded the whole environment to GCC4TI, as suggested by Adriweb on SAX
