So even on vacation I've found some time to program! I've gotten my CE portion of the builder nearly done, I think I like it better than CSP right now.
This is a craft I made with the build system, I'm going to make a save system soon.
Now I'm going to work on the 84+ version.
For some reason both wabbitEmu and Justified refuse to take in the file. (wabbit says the file is too large even though it's less than 1kb) so I'm going to try again with a different save.
EDIT: I tried a new save and it worked!
EDIT 7/30/2017: this is a small update so I'm not going to make an entire new post for this. But I've got save files compatible between color and monochrome calculators! I'm going to work on a way so instead of loading 5 lists, you'll only need to load 1. Also a later idea: I may add some small mod support. (i.e. just add more parts)
EDIT 3: so somehow I completely screwed up something and my program is now bugging out my calculator and jsTIfied. Also, apparently jsTIfied does not support ctrl+Y so my program is all screwed up now!
*sigh* I guess it's time to load that backup and restart...
***TheLastMillennial goes on a walk.
