There is a griefer hole in the nether. I was looking for a portal, went up what looked like someones staircase, and fell in a hidden hole built over lava. There was nothing else in this staircase, clearly a trap. And I lost my elytra, plus much much more, but the rest i can replace. Is there any way of regaining these items? I haven't left the server since it happened if that helps.
I cannot speak for the admins, but are you able to get a picture of the hole you fell in + coords?
EDIT: Also, when did it happen?
If you're stuff burned, unfortunately you're probably going to have to start from the beginning. Once admins/mods have some time, I'm sure they can look into whoever made the hole.
I got some screenies, he showed me the trap:
https://ibb.co/jdVmbQ
https://ibb.co/dU5xi5
https://ibb.co/cat6bQ
https://ibb.co/dQDTqk
https://ibb.co/b2ZjVk
Coords:
55, 33, -49 (in the nether)
Basically, just north of the spawn portals
Coords:
