No, there is going to be a huge setback because I actually need to learn ASM first. And that takes at least one month to learn. I also am busy with school right now. This is going to take a while...
» Forum
> Your Projects
This is my shackle for not doing everything that i want to in C... I need to actually learn it first!! ;P
Luxen wrote:
so, uhh, when you mean 2d ksp, you mean like this?.
Probably something similar to that, I'll draw some ideas from it and rearrange the building process and the launch so it's more calc friendly. I'm not sure if I'll include rovers since the calculator probably couldn't handle it.
I went through the learn to code in assembly in 28 days over the summer, and learned how to code in assembly ( although I haven't really written a fully functional program yet). Can I help with the programming?
A good idea would be to plan out the entire program before officially beginning the coding process. it will not only give you time to learn ASM (or C), but it will also create a solid foundation for the project and prevent confusion with respect to what exactly needs to be coded.
So I've decided no assembly for now, instead I'm making a Basic version of this. I've got the ship builder finished and now I just need formulas, LOTS of formulas. I have looked at several websites for the physics and astrodynamics equations. However, as you can probably guess it's rocket science, it's complicated. So my question is, does anyone know astrodynamics? or any physics equations that would be useful for this program? or maybe a website that could explain the formulas in laymans terms?
It shouldn't be to hard, all you really need is trigonometry and algebra. After all, it's only rocket science
Edit: if you write this in C or asm i will be willing to do a physics engine for it.
Tari
- Systems Wrangler (Posts: 3569)
- 21 Jan 2017 05:07:10 am
- Last edited by Tari on 21 Jan 2017 04:56:12 pm; edited 1 time in total
If I were to simplify a lot, you only need two equations:
F = ma, or perhaps rearranged to a = F/m. Given a known thrust (easily simplified to be constant or at least a simple fraction of maximum thrust) your acceleration is the thrust divided by craft mass.
Assuming some kind of known time step (easily implemented as a fixed frame step), mass of the craft changes at a rate roughly proportional to thrust (as a proxy for fuel flow).
Meanwhile, gravitational acceleration g = Gm/r2, where G is an arbitrary constant, m is the mass of the parent body (simplifying such that your craft has no gravity of its own since it's a very small mass) and r is the distance from the center of the parent body.
Then it's just a matter of doing vector addition, where a little trigonometry comes in handy (since it's easy to treat all bodies as spherical and you want some arbitrary common coordinate system). Acceleration due to thrust is a vector of magnitude a opposite the direction of thrust, and acceleration due to gravity is a vector of magnitude g towards the center of the parent body.
Actually, in KSP, the celestial bodies are "on rails", which means they literally cannot be moved (since this could cause them to fall into unstable orbits and maybe someday crash into each other). Therefore, it would be staying true to the original game if you ignored the gravity induced by the mass of your ship. Besides, the mass of a celestial body would be several orders of magnitude greater so any change in trajectory would probably be rounded out by the numbering system used.
Thanks Tari and mr womp womp! This was a huge help. I'll go work on implementing the formulas now.
c4ooo, That's a really nice offer. Of course it'll be a while before I can get started on an ASM version of this, but I'll keep your offer in mind.
I would recommend doing this in C if I were you; but that's just me Best of luck!
TheLastMillennial
- Official Cemetech Cake Manager (Posts: 2055)
- 14 Feb 2017 09:12:03 pm
- Last edited by TheLastMillennial on 07 Apr 2017 10:26:45 am; edited 1 time in total
So I've gotten the game to a fairly playable version now. However I'm running into some a strange bug. For some reason the program (ZLAUNCH) is spawning my rocket at y=8 instead of the y=5 (I set it at the beginning of the program.)
here's the link to the 3 programs needed to use this. (prgmCSP is the main program) I also put as much commenting as I could so it will be easier for you guys to figure out my code.
Link removed
If any of you could point out my (hopefully just a simple, stupid) mistake, that would be amazing! Also any optimizations would be greatly appreciated.
Forgot a ReadMe!
Use [enter] and the top 5 buttons to navigate most of the program. I think that's it for now.
EDIT: Hey I found and fixed the bug! (forgot I used a For( loop with the var Y in it)
Link removed
Forgot a ReadMe!
TheLastMillennial
- 17 Feb 2017 09:00:40 pm
- Last edited by TheLastMillennial on 07 Apr 2017 10:29:19 am; edited 1 time in total
MateoC (on SAX) wrote:
5:27:20PM [#] [MateoC] If you post code people would be happy to suggest optimizations
5:27:23PM [#] *MateoC hided
So I'm going to ask for suggestion
Also, I'm still not sure how to do the physics of this. (I'm taking physics and calculus next year)
Or download the programs link removed
Outdated code
prgmCSP
"Setup
ClrHome
Disp "CSP","Loading..."
"DECLARATIONS
"Misc-------------------
"Lists------------------
:"WORLD Chell
:"1 is mass
SetUpEditor ⌊CHELL
1→dim(⌊CHELL
1000→⌊CHELL(1)
SetUpEditor ⌊CSP11
5→dim(⌊CSP11
SetUpEditor ⌊CSP12
5→dim(⌊CSP12
SetUpEditor ⌊CSP13
5→dim(⌊CSP13
SetUpEditor ⌊CSP14
5→dim(⌊CSP14
SetUpEditor ⌊CSP15
5→dim(⌊CSP15
SetUpEditor ⌊CSP21
5→dim(⌊CSP11
SetUpEditor ⌊CSP22
5→dim(⌊CSP12
SetUpEditor ⌊CSP23
5→dim(⌊CSP13
SetUpEditor ⌊CSP24
5→dim(⌊CSP14
SetUpEditor ⌊CSP25
5→dim(⌊CSP15
SetUpEditor ⌊CSP31
5→dim(⌊CSP11
SetUpEditor ⌊CSP32
5→dim(⌊CSP12
SetUpEditor ⌊CSP33
5→dim(⌊CSP13
SetUpEditor ⌊CSP34
5→dim(⌊CSP14
SetUpEditor ⌊CSP35
5→dim(⌊CSP15
"Matrices---------------
:{5,5}→dim([B])
:"SETS UP MATRIX B (vab)
"Strings----------------
:"P/S| Fuel| Engn| Aero| -> →Str0
:"USED AS PARTS
::"→Str1
"Variables--------------
:"A for altitude
:"C is colum SEE R
1→C
:"D for direction
:"F IS FUEL
0→F
:"I IS PART ID
0→I
:"K is the getkey
0→K
:"M IS MASS
0→M
:"P is planet mass [zlaunch]
0→P
:"R is row SEE C
1→R
:"T IS THRUST
0→T
:"U untill empty(fuel consumed per second)
0→U
:"XY ARE PART CORDINATES
1→X
1→Y
"N and S are previous part coordinates
1→N
1→S
ClrHome
Output(2,12,"CSP
Output(9,23,"B.12
Output(10,23,"v.01
Pause
ClrHome
Disp " _____","| |","|/ / /|","|| | ||","|| | ||","|\ \ \|","|_____|"," VAB
Pause
ClrHome
"CLEARS MATRIX B
For(R,1,5
For(C,1,5
1→[B](R,C)
"PRINTS OUT GRID and ship
Lbl 1
Float
ClrHome
"prints out coordinates
For(X,1,5,1
Output(2,X+9,X
For(Y,1,5,1
Output(Y+2,9,Y
"Prints out ship
"NEEDS OPTIMIZATION--
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=1
Output(Y,X,"·
If [B](Y-2,X-9)=2
Output(Y,X,"▫
If [B](Y-2,X-9)=3
Output(Y,X,"Ŝ
If [B](Y-2,X-9)=4
Output(Y,X,"^
If [B](Y-2,X-9)=5
Output(Y,X,"/
If [B](Y-2,X-9)=6
Output(Y,X,"\
Output(9,1,"Mass
Output(9,6,M
Output(10,1,"Prt| <- |Sv/Ld|Launch|Ext"
0→K
Lbl W2
getKey→K
If K≠0
"P FOR PARTS
If K=11
Goto P
"Undo
If K=12
Goto U
"Save/Load
If K=13
Goto R
"LAUNCH
If K=14
Goto L
"EXITS
If K=15
Goto E
If K>15
Goto W2
Goto W2
Lbl P
ClrHome
Output(10,1,Str0
getKey→K
If K≠15 or K≠0
prgmZPARTS
ClrHome
"checks to continue or not
If X=1
Goto 1
"Part movement setup
1→X
1→Y
"since X and Y were taken
1→S
1→N
"Coordinates
For(X,1,5,1
Output(2,X+9,X
For(Y,1,5,1
Output(Y+2,9,Y
"Prints out ship
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=1
Output(Y,X,"·
If [B](Y-2,X-9)=2
Output(Y,X,"▫
If [B](Y-2,X-9)=3
Output(Y,X,"Ŝ
If [B](Y-2,X-9)=4
Output(Y,X,"^
If [B](Y-2,X-9)=5
Output(Y,X,"/
If [B](Y-2,X-9)=6
Output(Y,X,"\
"makes it store correct part
Lbl W1
If I=2
"▫→Str1
If I=3
"Ŝ→Str1
If I=4
"^→Str1
If I=5
"/→Str1
If I=6
"\→Str1
"Part movement
0→K
Repeat abs(Ans-63)=42
While [B](S,N)≠1
1+S→S
If Y=5
N+1→N
Output(Y+2,X+9,"·
S→Y
N→X
Output(S+2,N+9,Str1
getKey→K
If Ans=24 and N-1≥1
N-1→N
If Ans=25 and S-1≥1
S-1→S
If Ans=26 and 5≥N+1
N+1→N
If Ans=34 and 5≥S+1
S+1→S
"stores ID in correct place on list
I→[B](S,N)
Goto 1
"Undo
Lbl U
1→[B](S,N)
Goto 1
"Save/load
Lbl R
ClrHome
Menu("Save/Load","Save",S,"Load",R1,"Back",1
Lbl R1
Menu("Load","Save Slot 1",R2,"Save Slot 2",R3,"Save Slot 3",R4,"Back",1
Lbl R2
Listmatr(⌊CSP11,⌊CSP12,⌊CSP13,⌊CSP14,⌊CSP15,[B]
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=3
Then
150→F
200+M→M
Else
If [B](Y-2,X-9)=4
Then
300+M→M
5000+T→T
5+U→U
Else
If [B](Y-2,X-9)=5
If [B](Y-2,X-9)=6
Disp "Loaded!"
Pause
Goto 1
Lbl R3
Listmatr(⌊CSP21,⌊CSP22,⌊CSP23,⌊CSP24,⌊CSP25,[B]
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=3
Then
150→F
200+M→M
Else
If [B](Y-2,X-9)=4
Then
300+M→M
5000+T→T
5+U→U
Else
If [B](Y-2,X-9)=5
If [B](Y-2,X-9)=6
Disp "Loaded!"
Pause
Goto 1
Lbl R4
Listmatr(⌊CSP31,⌊CSP32,⌊CSP33,⌊CSP34,⌊CSP35,[B]
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=3
Then
150→F
200+M→M
Else
If [B](Y-2,X-9)=4
Then
300+M→M
5000+T→T
5+U→U
Else
If [B](Y-2,X-9)=5
If [B](Y-2,X-9)=6
Disp "Loaded!"
Pause
Goto 1
Lbl S
Menu("Save to","Save Slot 1",S1,"Save Slot 2",S2,"Save Slot 3",S3,"Back",1
Lbl S1
Matrlist([B],⌊CSP11,⌊CSP12,⌊CSP13,⌊CSP14,⌊CSP15
Disp "Saved!"
Pause
Goto 1
Lbl S2
Matrlist([B],⌊CSP21,⌊CSP22,⌊CSP23,⌊CSP24,⌊CSP25
Disp "Saved!"
Pause
Goto 1
Lbl S3
Matrlist([B],⌊CSP31,⌊CSP32,⌊CSP33,⌊CSP34,⌊CSP35
Disp "Saved!"
Pause
Goto 1
"LAUNCH
Lbl L
prgmZLAUNCH
If A=1
Goto 1
Lbl E
Disp "QUITTING...
DelVar L₁
DelVar L₂
DelVar L₃
DelVar L₄
DelVar L₅
Archive ⌊CHELL
Archive ⌊CSP11
Archive ⌊CSP12
Archive ⌊CSP13
Archive ⌊CSP14
Archive ⌊CSP15
Archive ⌊CSP21
Archive ⌊CSP22
Archive ⌊CSP23
Archive ⌊CSP24
Archive ⌊CSP25
Archive ⌊CSP31
Archive ⌊CSP32
Archive ⌊CSP33
Archive ⌊CSP34
Archive ⌊CSP35
"→Str1
"→Str2
"→Str3
"→Str4
"→Str5
Float
"END!
prgmZPARTS
Lbl 0
ClrHome
Output(10,1,Str0
0→K
Repeat K≠0
getKey→K
"GOTO POD
If K=11
Goto P
"GOTO FUEL
If K=12
Goto F
"GOTO ENGINE
If K=13
Goto E
"GOTO AERO
If K=14
Goto A
"EXIT
If K=15
Goto 98
"POD MENU
Lbl P
Menu("PODS","▫ Mk.1",P1,"BACK",0
Lbl P1
ClrHome
Disp "STATS:","MASS=2"
Output(10,1,"Continue Back"
Repeat max(K={11,12,15
getKey→K
If K=11 or K=12
2→I
If K=15
Goto 0
Goto 99
Lbl F
Menu("Fuel","Ŝ Mk.1",F1,"BACK",0
"Mk.1
Lbl F1
ClrHome
Disp "Stats:","Lf=150","Mass=200
getKey→K
If K=11 or K=12
3→I
If K=15
Goto 0
Goto 99
Lbl E
Menu("Engines","^ Mk.1",E1,"BACK",0
Lbl E1
ClrHome
Disp "Stats:","Thrust=2.5kN","Mass=300","5FpS
getKey→K
If K=11 or K=12
4→I
If K=15
Goto 0
Goto 99
Lbl A
Menu("Aerodynamics","/ Mk.1 LEFT",A1,"\ Mk.1 RIGHT",A2,"Back",0
Lbl A1
ClrHome
Disp "Stats:","LEFT","Stability= +1","Mass=.5"
getKey→K
If K=11 or K=12
5→I
If K=15
Goto 0
Goto 99
Lbl A2
ClrHome
Disp "Stats:","RIGHT","Stability= +1","Mass=.5"
getKey→K
If K=11 or K=12
6→I
If K=15
Goto 0
Goto 99
"returns so you DONT move a part
Lbl 98
1→X
Return
"returns so you can move the part
Lbl 99
0→X
Return
prgmZLAUNCH
"Prelaunch setup
ClrHome
Output(5,9,"Loading...
:SetUpEditor L₁
:7→dim(L₁)
:SetUpEditor L₂
:7→dim(L₂)
:SetUpEditor L₃
:7→dim(L₃)
:SetUpEditor L₄
:7→dim(L₄)
:SetUpEditor L₅
:7→dim(L₅)
"load variables
:"A for altitude
1→A
:"B for accelleration (bad var)
:"D for direction or tilt of craft
0→D
:"K is getKey
0→K
:"M is rocket Mass
:"S is speed
0→S
:"T is thrust
0→T
:"U is FpS
0→U
:"V is verifacation +1 per correct part
0→V
:"postion of ship
16→X
5→Y
"Load HUD strings
"Altitude-< >-→Str0
"get matrix into lists
Output(6,5,"Matrix to list
Matrlist([B],L₁,L₂,L₃,L₄,L₅
"verifys all needed parts are present
Output(6,5," Verifying...
If inString(toString([B]),"2"
Then
1+V→V
Else
Disp "Error","No pod!"
Pause
ClrHome
Return
If inString(toString([B]),"3"
Then
1+V→V
Else
Disp "Error","No fuel!"
Pause
ClrHome
Return
If inString(toString([B]),"4"
Then
1+V→V
Else
Disp "Error","No engine!"
Pause
ClrHome
Return
"loads ship parts
Output(6,5," Loading parts
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=3
Then
150→F
200+M→M
5+U→U
Else
If [B](Y-2,X-9)=4
Then
300+M→M
2500+T→T
5+U→U
Else
If [B](Y-2,X-9)=5
Then
"No stability in this version
"1+S→S
If [B](Y-2,X-9)=6
Then
"1+S→S
"get lists to a string
Output(6,5,"List to string
:For(X,1,dim(L₁
:Ans+sub(" ▫Ŝ^/\",L₁(X),1
:End
:sub(Ans,2,length(Ans)-1→Str1
:For(X,1,dim(L₂
:Ans+sub(" ▫Ŝ^/\",L₂(X),1
:End
:sub(Ans,2,length(Ans)-1→Str2
:For(X,1,dim(L₃
:Ans+sub(" ▫Ŝ^/\",L₃(X),1
:End
:sub(Ans,2,length(Ans)-1→Str3
:For(X,1,dim(L₄
:Ans+sub(" ▫Ŝ^/\",L₄(X),1
:End
:sub(Ans,2,length(Ans)-1→Str4
:For(X,1,dim(L₅
:Ans+sub(" ▫Ŝ^/\",L₅(X),1
:End
:sub(Ans,2,length(Ans)-1→Str5
"calcs thrust (planet mass + rocket Mass)
Output(6,4," Thrust
If inString(toString(T),""
T*-1→T
T-(⌊CHELL(1)+M)→T
ClrHome
"outputs HUD
Output(1,1,Str0
Output(1,12,A
"Speed
Output(2,10,"MpS
Output(2,13,"0
"Fuel
Output(8,1,"Fuel
Output(9,1,F
Output(6,23,"___
Output(6,23,D
Output(6,26,"°
Output(7,22,"/ \
Output(8,22,"| |
Output(9,22,"\___/
"REASSIGNED CUZ OF FOR( LOOP
5→Y
"outputs final ship-----------
Output(2,1,"[ENTER!]
Output(Y,X,Str1
Output(Y+1,X,Str2
Output(Y+2,X,Str3
Output(Y+3,X,Str4
Output(Y+4,X,Str5
Pause
Output(2,1,"LAUNCH!
Output(2,1,"
"Just looks neat
Y-1→Y
Output(Y,X,Str1
Output(Y+1,X,Str2
Output(Y+2,X,Str3
Output(Y+3,X,Str4
Output(Y+4,X,Str5
Output(9,8,"
Fix 2
"Actuall Launch--------------------
Lbl 0
0→K
"Flight end checker
" If clear is pressed or if Altitude is less than 0
Repeat K=45 or A<0
getKey→K
"Fuel and thrust check
If F<0
Then
0→U
T*1→T
0→F
"Just looks neat
Y+1→Y
"Domain error######
Output(Y,X,Str1
Output(Y+1,X,Str2
Output(Y+2,X,Str3
Output(Y+3,X,Str4
Output(Y+4,X,Str5
"Calculations___________________
"accelleration
T/M→B
"momentum
M*B→S
"simple calc for altitude
A+S→A
"Fuel depletion
F-U→F
Output(1,1,Str0
"displayes altitude
Output(1,12,A
"Displayes speed/ aceleration
Output(2,13,S
"Disp fuel
Output(9,1,F
Pause
Menu("Options","Resume",0,"Revert to VAB",98,"Quit",99
Lbl 98
"so it'll go to VAB
1→A
Return
Lbl 99
"so it'll quit
0→A
Return
Sorry about the double posting, I thought my post would look cleaner if I just made a new one.
Anyways, any suggestions would be nice, I feel like I'm at a good spot to make major changes to the code without messing everything up.
Here comes PT_ the bytekiller!
First of all, please use SourceCoder to write these programs, SC allow comments with "// <comment>", instead of putting strings everywhere, which can be useful, although it's slow. When you replace this comments why "// <comment>", I'm sure you could increase the speed to like 130% .
Next, I see some For-loops, which have step size 1. You can omit the 1, which should save 2 bytes.
can be
It is... faster and smaller
can be
This code is more complicated, especially the sum(DeltaList( part. Ans={24,26} returns a list which is {1,0} if getKey=24, {0,1} if getKey=26, and {0,0} if none of the keys was pressed. DeltaList calculates the Xth argument of this list minus the (X-1)th argument of this list, so if getKey=24, DeltaList returns {0-1}, and if getKey=26, it returns {1-0}. Take the sum of this list, you get either -1, 0 or 1, which is what we need. Since both N and S are bounded by [1,5], I used a max( and min( as well.
Next, you have a bunch of lowercase letters, which is fine, but they are 2 bytes each. You can change this to uppercase letters, which are 1 byte tokens, but that's up to you.
Also, I see somewhere a
which doesn't make sense at all. You can just remove the "Else"
can be
Disp "<string>":Pause can be Pause "<string>"
If K=11 or K=12 can be If max(K={11,12
My last tip is that you can omit parenthesis at the end of a line, so If [B](Y,X)=3 can be If 3=[B](Y,X
I'm sure there are a bunch of more optimizations, but with these you should be able to speed it up. Good luck with it!
For(X,10,14,1
For(Y,3,7,1
If [B](Y-2,X-9)=1
Output(Y,X,"·
If [B](Y-2,X-9)=2
Output(Y,X,"▫
If [B](Y-2,X-9)=3
Output(Y,X,"Ŝ
If [B](Y-2,X-9)=4
Output(Y,X,"^
If [B](Y-2,X-9)=5
Output(Y,X,"/
If [B](Y-2,X-9)=6
Output(Y,X,"\
can be
For(X,1,5
For(Y,1,5
Output(Y,X,sub(".▫Ŝ^/\",[B](Y,X),1
If Ans=24 and N-1≥1
N-1→N
If Ans=25 and S-1≥1
S-1→S
If Ans=26 and 5≥N+1
N+1→N
If Ans=34 and 5≥S+1
S+1→S
can be
max(1,min(5,N+sum(DeltaList(Ans={24,26->N
max(1,min(5,S+sum(DeltaList(K={25,34->S
Else
If [B](Y-2,X-9)=3
Then
150→F
200+M→M
Else
If [B](Y-2,X-9)=4
Then
300+M→M
5000+T→T
5+U→U
Else
If [B](Y-2,X-9)=5
If [B](Y-2,X-9)=6
can be
For(X,1,5
For(Y,1,5
If 3=[B](Y,X
Then
150->F
M+200->M
If 3=[B](Y,X
Then
M+300->M
T+5000->T
U+5->5
If max({5,6}=[B](Y,X
One little thing, you can use the equation variables for things that recur a lot, it won't slow you down, but it will chop off some bytes. For example:
could be:
EDIT: lets do better...
Also, the SetUpEditor command can take multiple arguments, so this:
could be
However, I don't know why you are using SOOOO many different lists
Same goes for the default lists, except that by default, SetUpEditor already does those, so
could be
For(X,1,dim(L₁
For(X,1,dim(L₂
For(X,1,dim(L₃
For(X,1,dim(L₄
For(X,1,dim(L₅
could be:
"sub(Ans,2,length(Ans)-1→u
For(X,1,dim(L₁
u→Str1
For(X,1,dim(L₂
u→Str2
For(X,1,dim(L₃
u→Str3
For(X,1,dim(L₄
u→Str4
For(X,1,dim(L₅
u→Str5
augment(L₁,augment(L₂,augment(L₃,augment(L₄,L₅→L₁
For(Y,0,4
For(X,1,7
Ans+sub(" ▫Ŝ^/\",L₁(X+7Y),1
If not(Y
Ans→Str1
If Y=1
Ans→Str2
If Y=2
Ans→Str3
If Y=3
Ans→Str4
If Y=4
Ans→Str5
7→dim(L₁
SetUpEditor ⌊CHELL
1→dim(⌊CHELL
1000→⌊CHELL(1)
SetUpEditor ⌊CSP11
5→dim(⌊CSP11
SetUpEditor ⌊CSP12
5→dim(⌊CSP12
SetUpEditor ⌊CSP13
5→dim(⌊CSP13
SetUpEditor ⌊CSP14
5→dim(⌊CSP14
SetUpEditor ⌊CSP15
5→dim(⌊CSP15
SetUpEditor ⌊CSP21
5→dim(⌊CSP11
SetUpEditor ⌊CSP22
5→dim(⌊CSP12
SetUpEditor ⌊CSP23
5→dim(⌊CSP13
SetUpEditor ⌊CSP24
5→dim(⌊CSP14
SetUpEditor ⌊CSP25
5→dim(⌊CSP15
SetUpEditor ⌊CSP31
5→dim(⌊CSP11
SetUpEditor ⌊CSP32
5→dim(⌊CSP12
SetUpEditor ⌊CSP33
5→dim(⌊CSP13
SetUpEditor ⌊CSP34
5→dim(⌊CSP14
SetUpEditor ⌊CSP35
5→dim(⌊CSP15
{1000→⌊CHELL
SetUpEditor CSP11,CSP12,CSP13,CSP14,CSP15,CSP21,CSP22,CSP23,CSP24,CSP25,CSP31,CSP32,CSP33,CSP34,CSP35
5→dim(⌊CSP11
5→dim(⌊CSP12
5→dim(⌊CSP13
5→dim(⌊CSP14
5→dim(⌊CSP15
5→dim(⌊CSP11
5→dim(⌊CSP12
5→dim(⌊CSP13
5→dim(⌊CSP14
5→dim(⌊CSP15
5→dim(⌊CSP11
5→dim(⌊CSP12
5→dim(⌊CSP13
5→dim(⌊CSP14
5→dim(⌊CSP15
:SetUpEditor L₁
:7→dim(L₁)
:SetUpEditor L₂
:7→dim(L₂)
:SetUpEditor L₃
:7→dim(L₃)
:SetUpEditor L₄
:7→dim(L₄)
:SetUpEditor L₅
:7→dim(L₅)
SetUpEditor
7→dim(L₁
7→dim(L₂
7→dim(L₃
7→dim(L₄
7→dim(L₅
TheLastMillennial
- 18 Feb 2017 10:24:25 pm
- Last edited by TheLastMillennial on 25 Mar 2017 07:24:37 pm; edited 1 time in total
Thanks guys! I'll start working on that!
PT_: I will take your advice and try to use SourceCoder. However I'm having some trouble getting a ROM image off my CE so I can use jusTIfied.
mr womp womp: the reason I have so many lists is for my save/ load function. because I'm limited on matrices (they could get overwritten by another program) I decided to use something that wouldn't interfere with another program. If there is a better way to do this I'm open to ideas, but for now I don't know a better way.
EDIT: wait, jusTIfied can emulate a CE right?
EDIT 2: Dang, I just got put on POTM! (Thanks guys!) So I'm really going to have to kick myself in gear to figure out this rocket science. Should be fun!
Nope, jsTIfied can't emulate the CE yet, we are working on that although progress go slowly
You can download the programs though with SC and transfer it to CEMUor a real calc
Also, in the declarations, something like
Can be
0->X
0->Y
Can be
DelVar XDelVar Y
^This
Every tick, add the vector of each force, then divide the resulting vector by mass of the craft, and that is your acceleration vector. Add acceleration to velocity and then velocity to position.
Thrust should already be given from the engine's specifications and the throttle.
Interestingly, I've run into a very similar problem earlier - actually for Kerbal Space Program, I was writing a trajectory calculation tool for extremely low TWR spacecraft, which couldn't be approximated with point burns. What I ended up doing was to set a time step ("frame"), calculate the total applied acceleration in this frame, approximate the long burn as a set of tiny ones, one every frame, after every burn I calculated the new orbit and advanced by one frame by advancing the vessel's true anomaly by the given amount.
All in all, it was a big mess and I never succeeded, but I believe this is the way to go. I.e. use Keplerian coordinates, not Cartesian, when dealing with orbits. Really, the other way round it's even more pain.
EDIT:
Up until now, everyone seems to assume that the thrust vector goes through the center of mass, which is not at all necessary. This makes things more complicated, requiring to take rotation into account.
EDIT:
Page 2 of 5
