My long-latent interest in trains and model trains has recently been rekindled, so I've been exploring the current state of N scale model trains. To paraphrase my recent topic about improving an N scale P42 diesel locomotive to have more realistic lighting, I've been considering a layout modeling the area I travel through during my frequent commutes between New York, NY and Burlington, VT, and along that route, I frequently see Acela express passenger trains speeding past. It stands to reason therefore that I'd be interested in exploring modeling Acela trains. The easy solution would be to buy Bachmann's N scale Acela train set, which includes two locomotives, a cafe car, two passenger cars, and a DCC controller and track. Pretty cool for <$300, right? Not so fast: I was disappointed to learn that neither of the locomotives actually has a motor inside. Instead, because the Acela trains are rarely separated into individual cars, the cafe car is actually the one with the motor, and the locomotives just have a board that reads motor instructions in order to light up headlights and tail lights. It seems that the components of an Acela consist are rarely separated, and that Federal Rail Administrations restrict the cars or engine from being run on main lines separately, but it still seems like a fun project to me to make the locomotives actual locomotives.
Helpfully, Bachmann sells just the locomotives as a two-unit set for $75. Like the cars included in the $300 set, they have DCC lighting boards inside, non-standard couplers to connect to each other or to Acela passenger/cafe cars, but no motors. Far be it from me at this stage in the hobby to consider trying to outfit these cars with motors, gears, and electrical pickups from scratch, so I tried to think what else I might use as a base. Happily, Bachmann also created a model of the Bombardier-Alstom HHP-8, an electric locomotive that Amtrak ordered around the same time as the Acela trains. The Bachmann model has a very similar body to the Acela locomotives, has the exact same wheelbase (spacing between the trucks), has identical structure around the wheels, and even has a DCC decoder built in. Therefore, I wanted to try to use the mechanical and electrical components from an HHP-8 to make one of the Acela locomotives work, and if that succeeded, to do the same to the other one. Happily, possibly because the real HHP-8s have been retired for poorly reliability and high maintenance costs, the N scale HHP-8 can be purchased for under $60.
When I purchased these two, I wasn't sure if I could actually make this work. There was nothing for it but to take the Acela locomotives (Bachmann #81551) and the HHP-8 locomotive (Bachmann #83054) apart and see what I found. The following five photos compare the interiors of the two locomotives, from the size and materials used for the bodies to the very similar PCBs inside each locomotive to the different undercarriage components. The bodies are nearly the same length; the HHP-8 has a steep slope at both ends, while the Acela locomotive has a shallower slope at one end. The HHP-8 has both mechanically and electrically working pantographs, while the Acela locomotive's pantographs don't connect to the board. Speaking of the control PCBs, they appear identical. The Acela locomotive's board is only missing a few passive components no doubt important in motor control, like the two prominent (hand-wound?) coils on the HHP-8's board.
At this point, it looks like I'll need to machine the front of the metal HHP-8 body to slim down the front and remove the protruding metal piece. I currently lack a rotary tool, so I'll need to either resolve that or be very patient with manual tools. I'll probably spend further time examining exactly what will be needed to (1) make the Acela shell fit over the HHP-8 body, (2) make the Acela light pipes line up with the HHP-8 LEDs, (3) replace the original HHP-8 LEDs with brighter ones, (4) fit the Acela undercarriage and couplers on the HHP-8, and (5) make the Acela's pantographs electrically functional. For bonus points, I may try to populate the missing components on the Acela's PCB.
Edit: For the sake of LED-purchasing, the HHP-8 is dropping 2.83V across the white LED, and 1.78V across the red LED. The Acela is the same.
