So I am totally new to this thing, and I'm just trying to upload a .8xp file to SourceCoder3 and an error comes up that says "Error: Unable to load _RADICAL2.8xP. Are you sure it's a valid file type?" How can I convert it to the correct file type? Any help would be much appreciated
Random suggestion: Have you tried renaming "8xP" to "8xp." And "_RADICAL2" to "RADICAL2"? Calculator programs can only be 8 characters in length, the name provided is 9.
If that doesn't work, are you able to link us to the the file you are trying to upload?
Ok, so I tried renaming it to something shorter and It came up with the same error
![Sad](images/smiles/icon_sad.gif)
How can I link the file to you?
Welcome to Cemetech! Did you write the program yourself, or download it from a site like ticalc.org? If the former, you can link us to the page from which you downloaded it.
Thanks, The program was written on a Ti-84+SE, not online.
How did you get it off the calculator? Just using TI-Connect?
One of my friends took it off then emailed the file to me
Edit: Sorry, I'm probably not being very helpful :/
If you rename it to RADICAL.txt and open it in a text editor, does it look garbled?
And also whenever I try to right-click the file to send it to my TI-84 directly, it says "incompatible type"
Can you upload the file here for me, thanks.
http://comicidiot.com/user_upload/index.html
I gave you a different one, but all of the ones that I have came up with the same error
Nvm, I just got sent another version in a form that works, but thanks so much for the help!
![Very Happy](images/smiles/icon_biggrin.gif)
I've taken the upload form offline then. Do you mind sharing how you got it to work in case someone else has a similar issue?
