acronymforme wrote:
I bought a CE a few weeks ago and I am about ready to throw it into Tampa Bay. Now I carry both the CE and the Silver with me. Why look like a fool when I go into class and tests with 2 calculators? It's because the CE removed the ability to answer questions automatically in fraction format. Here's an example. On the CE type in the fraction 2/3. It will convert to the decimal .6666666667. Awesome. Now - try to convert that back into a fraction. You can't. You can't until the end of time. So, tell me, how awesome is that? To have all of your answers in decimal format where you might or most likely will not be able to convert back into a logical and recognizable value? Calculating function graph intercepts and values in Calculus are also real fun when 2 decimal points are dropped from the x values displayed as decimals that I will never be able to convert into a fraction on this device. This calculator should come with a crystal ball to help me guess. What makes it a real party favor is the fact that Pearson Edu Math applications require all the answers on homework, quizzes, tests, midterms and finals to be entered as fractions! This thing is an overpriced piece of useless junk. Sure it has pretty color and a lot of features - but the basics, the basic taken for granted things you depend on to work are not there. That makes the CE undependable. I chalk it up to lazy programming which was most likely outsourced to save a few bucks.
If you press [math] and select the >Frac option, it will convert the answer back into fractional form.
