- Need help with assembling program correctly.
- 08 Jan 2016 09:41:06 pm
- Last edited by KKZiomek on 08 Jan 2016 09:45:52 pm; edited 2 times in total
(I apologize if this post hard to read or have grammar errors but I learned english not long ago and is still foreign languge to me.)
Hi, I'm new to this forum even I'm visiting it from long time to see progress on Doors CE 9.
I'm advanced C++ and Assembly programer.
Recently I tried building an example program to see if it assemble correctly. The thing is that it requires to run devpac8x.com which won't run on 64-bit Windows 8.1. I downloaded binpac8x.py, the 64 bit version and tried to link my .bin file generated with TASM. It didn't work. Then I saw the Brass compiler/linker and SPASM.exe. I used both of they and it still didn't work. My calculator displays: "ERROR: INVALID". I'm not new to programing, but I couldn't find one z80 tutorial that had stable information. Every tutorial I find have totally different syntax of hello world programs so I'm really confused. What I want is exact directions and links to specific files to use to compile programs in the below tutorial correctly.
(P.S. I tried using Doors CS SDK and didn't work correctly too)
I used this tutorial: http://www.ticalc.org/archives/files/fileinfo/268/26877.html
My calculator: TI 84+ CE
Thank you in advance!
