- Christmas Tree project
- 18 Dec 2015 02:37:40 pm
- Last edited by Caleb_J on 14 Jan 2016 10:16:53 am; edited 5 times in total
Note: In ALL posts, if it's red, I have not started on it yet. If it's yellow, I'm working on it. If it's green, that means it's solved.
All right then. I was hoping that I could keep this a secret, and have a surprise for everyone for New years, but I can't hide it anymore.
It's a ASM program that simply draws a green Christmas tree on the screen and has color-changing lights. So far, I've worked out the colors that I want it to be(here they are), and I know how to make a specific pixel a specific color, as illustrated by Kerm here:
My problems are:
And a question: Does eZ80 need a loop like TI-Basic does? Because with basic, there has to be a Repeat or a While if you want the commands to execute more than once. Also, would it be better to have it in 16bpp mode, or 8bpp mode?
EDIT: Looking at the above code, I just realized that I would have to write each block of code HUNDREDS of times to get each light to be every color that I want it to be. Is there a simpler/shorter way to write the above code? This way, I wouldn't have to write hundreds of blocks of code. To be specific, I don't want to have to write a individual block of code for each pixel, for each color. Because if I have 100 pixels that change color, and 100 colors, that works out to 50,000 lines of code, which is not counting setup, or drawing a green tree, or anything else. I think there's a better way to do this, rather than writing... well, you know.
To do list (so far)
ld de,$ffff ; white
ld hl,VRAM + (0 * 320 ) + (0 * 2)
ld (hl),e
inc hl
ld (hl),d
ld de,$0000 ; black
ld hl,VRAM + (239 * 320) + (319 * 2)
ld (hl),e
inc hl
ld (hl),d
call _getkey
Ret
My problems are:
1. Getting a actual tree onto the screen.
2. Getting the program to exit on the press of any key
3. I might have to put a delay in here. Just to make sure that the lights on the tree aren't going so fast that you can barely tell what color each light is.
To do list (so far)
- 1. Figure out how to write a sprite routine.
2. Get a pixel onscreen.
3. Get that pixel to change color
4. Get a bunch of pixels to change color
