- gCn Helper, the easy-ish gCn setup program
- 09 Jun 2014 12:07:55 pm
- Last edited by Luxen on 09 Jun 2014 12:20:32 pm; edited 1 time in total
So, some time ago, I released a program called gCn Helper. it was made to assist people who had no experience with using a command line, by providing an interface for selecting options.
Download here at TICalc.org
While not complete, it does work for DirectUSB, and I think that the other USBHID and Arduino options may work (though, no one has ever tested this).
Basicly, it takes the input from the user, and builds the command line for the gcn client from that. nothing fancy. it DOES require that you can run the gCn Client (ie filter driver installed) and it DOES require that the gcn client be in the same directory (unzip it yourself, I dont think that the downloader button unzips it properly, if at all).
also, futher development on this wont happen, since it is made in the Multimedia StudioII, which is no longer registered to me. I may buy it again, though, to rewrite this application from scratch.
