TI-Freak8x wrote:
I came across an interesting discovery. I am trying to find the most optimized way to do 'event flags' in Pokemon, and I find that you store 10 to dim(L5, it will be 102 bytes in size. You can also store any value within the slots, and the size never changes. What I am wondering is is there a way to search for a specific digit using BASIC. I have never tried, but I thought maybe someone here has, to see if it was possible...
Otherwise, I could use strings, which would probably be a mem saver, but I still do not know how many strings I will need for me game...
Ummm...I gave you routines to do this...and it's bit compressed...
Also, complex numbers take twice the space as real ones, so as long as they're all reals, you don't need to worry about size changing.
Code for isolating digit in real number sotred in L1(Z):
Code: :For(A,0,ipart(log(L1(Z
:If [testvalue]=ipart(10Fpart((10^-(A+1))*L1(Z
:Then
:End
Basically uses logarithms and clever ipart()/fpart() manipulation to grab a digit. I came up with this for another program I made but lost to a RAM clear.
Yeah, that's basically the way I usually do it.
yeah, I made a digit extractor like that once or twice for base converters, and parsing numeric input to create Stat-sprites.
:Then
:End
for a slight speed improvement, read L1(Z) to a variable (A-Z, theta) if you have to extract more than one digit (it takes alot longer for BASIC to read/write to lists than to variables)
When I ran the programs, the only thing it did was add or subtract an 8 digit number, I couldn't get it to do anything else...
Thanks guys, I will look at it.
:Then
:End
I'm assuming that TI freak needed to search an entire list, but variables work just as well.
I can just store the list element into a variable.
This way, I can reduce the number of list elements, and save a ton more memory.
K, great. Care to post the final routine you ended up with?
...thats what i said
I was talkin in reply to Kuro.
Also, yes, once I get it done, I will post the finished code.
That's what they're supposed to do. Use the Test Routine to read the bit (S is 1 if that flag is set and 0 otherwise). Just because you dont recognize how it's stored doesn't mean it's not working. If you were to use a base converter to convert the number to binary, you would see the ones and zeros being set and unset in the string it outputs. The calc just turns it into decimal because that's what it does. Changing the flag to (un)set will change how much the number is changed by an appropriate amount.
I assume you mean storing each element as a separate variable, and not as taking an element and then storing it to a var.
Ohhhhh! That is what I didn't understand... Why didn't you just say that?
Now I need a converter thingy to make it so I can see what I am doing...
