Hello, all. I have been trying to start programming in XlibC, but I have a problem. I do not know how to make tilemap correctly, as when I try it, the result is a garbled mess. Is there any simpler way to tilemap rather than typing out the code manually?
Any chance you can post up your code you are using? We might be able to assist you in pointing out your error
We will definitely be able to assist, but as tifreak mentioned if you are able to provide us with some example code and data (sprite data+tilemap data)? We can check it out!
This is how I organized the code, with a data string "mirroring" the screen.
0000002900003130000000310029000000260031
0000002900003130000000140029000000260031
0001020304050607000000310029000000260031
1011121314003130000000310029000000260031
2021223031003130000000310029000000260031
3031330334003130000000310029000000260031
4041431344003130000000310029000000260031
5051529354003130000000310029000013260031
6061626364003153545556570029000000260031
7071727374003130000000310029000000260031
0000000000003153747576770029000000260031
0000000000003130000000310029000000260031
0000000030003130000000310029000000260031
[/img]
[/img]
