As stated above, I've been doing my research. The CPU is an AM3 Socket type (not AM3+). Which, is dated as I think Tari pointed out on IRC earlier in the week.
So, spending as little money as possible I can update the motherboard to an
AMD 760GM (from an 880GM) and then buy a moderate graphics card. Bring my total around 250 bucks.
If I wanted to just
update the CPU to FM2 Plus while I'm at it, upgrade to an
Motherboard to work with it and then the
same moderate graphics card for about 450 bucks. I still need to find out if my PSU can power this GPU but I figured I'd share where I'm at.
I can pick up all these parts from my local Frys store which will save with shipping and for ease of return.
Now, the alternative is
to build this.
I've found the following while researching:
- Your CPU can stay "up-to-date" for about 4 years. (1) (2)
- The GPU should see an upgrade every two years. I really found answers all over the place on this one, split between 2 years and when it can't run games very well. I decided to go with the former since this is about maintaining a good build. (3)
To save money I'd buy a mid-range GPU ($250) every 2 years and a CPU ($200) every 4. Assuming my current CPU socket type is no longer supported, I'll have to upgrade the motherboard as well ($150).
So, I'd see about $200 under price of the alternative build in about 4 years. Since I've spec'ed out the alternative build as high as plausible, I could probably squeeze 4 years out of the GPU before I start the 2 year GPU upgrade cycle. In conclusion, it's not really going to matter one way or another which way I go but using this computer is a bit cheaper.
Reason for the Mini-ITX case: Coming from the Mac realm I really dislike the plastic feel of most computer cases with Windows. A Mini-ITX case was a good compromise between looks, durability, and cost. I'm also displeased with the amount of ports on these Windows motherboards. I don't need a PS/2 port (or two of them for that matter), six analog audio ports. Ideally, I just need an RJ-45, HDMI/VGA/DVI, Optical, and USB (and none of that 2 USB3.0 and 4 USB 2.0.) Do such motherboards exist? The motherboard I picked out has Optical, HDMI/DVI/VGA and an RJ-45, so removing the other junk shouldn't be too far out of the question...
