- Ignition, the Esoteric Programming language
- 01 Apr 2014 01:33:45 pm
- Last edited by Luxen on 07 Apr 2014 03:54:47 pm; edited 1 time in total
So, some time ago I was asked to simplify TI-Basic by a lazy classmate, who didnt want to learn TI-Basic.
so I made Ignition, which is an ugly-@$%& interpreted programming language. I have included the project in the dropbox link here:
https://dl.dropboxusercontent.com/u/107246250/IGNITION.8xg
essentially, this nasty peice of work isnt like many other programming languages. EVERYTHING is data. simply when data is recognised as a key, then execution occurs. only when data has a label in front of it can it be accessed.
these are the commands, with the closest definition following:
I hope I got all of them. I may have forgotten one or two.
One extra note. To do anything, you have to load the data from your program into Var1, Var2, or Var3.
Example programs:
Hello World:
Random Number Guessing Game:
Slightly optimized Random Number Guessing Game
As you can see, I dont think this language would be any use to anyone. ever. its horribly made, and cant do squat. it isnt even similar to any languages I have heard of (if you can prove me wrong, ill laugh, and likely puke, too). so,its mainly as a joke.
however, when spud needed a weak language to run for his userscript (Forum Here), immediately my mind drifted to Ignition, and so I have reawakened it. who knows, I may even work on an Asm-based interpreter for it, so execution is at least faster.
If anyone can find a use for this, go ahead and post.
A Freind at school wrote:
"I Find that TI-Basic is too much work to understand. could you make something that would write code and run it, for me?"
-)Creates a label. follows BATCH type. ex: ":LABEL"
Jump x
-)Causes the interpreter to find the first label with the text x, and continues execution there.
Comp
-)Compares Var1 to Var2. if false, the following line is skipped.
Load Var#,x
-)Stores the value after label x to Var#
Save Var#,x
-)Stores the value in Var# to the line after label x
-))Not implemented into the TI-Basic interpreter yet.
Swap Var#,Var#
-)Saves the data from the first Var# to the second Var#
Clear
-)Clears all text on the screen
Print
-)Prints the data in Var1
Input
-)Gets a string and stores it to Var1
Rand x
-)creates a random number from 0 to x
Quit
-)Ends program execution. in the TI-Basic interpreter, this is often neccesary.
Math x
-)performs operator x (+,-,/,*) to Var1 and Var2, storing the contents in Var1.
igni
-)more a header to make sure the interpreter doesnt attempt to run bad code.
-)supposed to be the name of your program, to get around TIOS shortnames, but since the program is in a string, it doesnt do anything. also, isnt neccesary for the interpreter.
type:x
-)supposed to be the type of your program. i often call mine "Game", "Utility", or "Other".
Example programs:
Hello World:
igni
type:other
:Start
Load Var1,String1
Print
Quit
:String1
Hello World!
:EOF
Quit
igni
name:Guess my number
type:game
:Start
Clear
Rand 10
Swap Var1,Var2
:Game
Load Var1,message1
Print
Load Var2,message2
Print
Input
Comp
Jump Win
Load Var1,msgLose
Print
Jump Game
:Win
Load Var1,msgWin
Print
Quit
:message1
Guess my number
:message2
any, 1-10
:msgLose
Try Again
:msgWin
You guessed right!
:EOF
Quit
igni
type:game
:Start
Guess my number
Clear
Rand 10
Swap Var1,Var2
:Game
any, 1-10
Load Var1,Start
Print
Load Var2,Game
Print
Input
Comp
Jump Win
Load Var1,EOF
Print
Jump Game
:Win
You guessed right!
Load Var1,Win
Print
Quit
:EOF
Try Again
Quit
