I have a TI84PCSE and a linux computer with TiLP. I want to send programs and download the rom from it but TiLP won't work. /home/tim/Desktop/TIStuff/Screenshot from 2013-11-05 18:37:38.png
/home/tim/Desktop/TIStuff/Screenshot from 2013-11-05 18:38:06.png
/home/tim/Desktop/TIStuff/Screenshot from 2013-11-05 18:38:24.png
/home/tim/Desktop/TIStuff/Screenshot from 2013-11-05 18:38:49.png
I hope you can help me.[/img]
1) I moved this to Technology/Calculator Open Topic, the correct subforum
2) Upload your images to
http://imgur.com and put them in [url] or [img] links
3) We need more details than "TiLP won't work". What did you try? What happened? What solutions did you attempt?
<a href="http://imgur.com/Wm1xCvS"><img src="http://i.imgur.com/Wm1xCvS.png" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/UZparg2"><img src="http://i.imgur.com/UZparg2.png" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/JHuFitn"><img src="http://i.imgur.com/JHuFitn.png" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/WgtJnuu"><img src="http://i.imgur.com/WgtJnuu.png" title="Hosted by imgur.com"/></a>
Did you try a direct link (microUSB) cable?
In your picture, you have a TI-84+ but selected a Graph Link cable.
Why? Just use a MicroUSB cable with it.
Also, did you install the patch and did you run TILP with sudo?
And did you add yourself to the tilp group?
Code: wget https://launchpadlibrarian.net/79510370/new-devices-and-fixed-sysfs-warning.patch
sudo patch /lib/udev/rules.d/45-libticables.rules < new-devices-and-fixed-sysfs-warning.patch
Code: sudo usermod -a -G tilp $USER
I've gotten TILP to work by using the commands above, logging off, logging back in, then starting it with this command:
Code: sudo tilp --calc=ti84+ --cable=DirectLink
"DirectLink" is for MicroUSB cables.
The calculator is indeed not detected, so TILP will have a hard time working alright
Did you compile TILP yourself through
http://lpg.ticalc.org/prj_tilp/download/install_tilp.sh (which is the best way to have a TILP install which works) ?
You must first go to "Change device" menu, click search button, then select the device from list.
Did the program compiled/instaled ok?
le : I need to run the program as root user, as the libs needed to be installed in root-level directories so tilp cannot load them without root-access. Also, manual compile/install it. The verbose level is higher and you know what you need to do later.
le2 : @amihart : I have installed tilp without the patch and it works like a charm.
