elfprince13 wrote:
Yeah, I'll see about packaging it up for you
Thanks! Should be interesting to see how it works out. src/World.java line 297, 357, 373, 436, 503, 533, 937, 1040, 2619, 3092, 3150
**4094!!** **4102!!**
WorldClient.java line **140**
src/World.java lines 856-858, 788-790, 1004-1006
src/BlockLilyPad.java line 81
BlockMushroom.java line 97
Chunk.java line 1206-1208
ChunkCache.java line 72, 198, 231, 315, 320, 385, 390, 407
DedicatedServer.java lines 153-155
EntityFallingSand.java line 170
IntegratedServer.java line 29
Interesting note: hashCode() in NextTickListEntry.java line 53 permits yCoords up to 1023
diff -r old/minecraft/net/minecraft/server/MinecraftServer.java new/minecraft/net/minecraft/server/MinecraftServer.java
214c214
< var8 = new WorldSettings(par3, this.getGameType(), this.canStructuresSpawn(), this.isHardcore(), par5WorldType);
> var8 = new WorldSettings(par3, this.getGameType(), this.canStructuresSpawn(), this.isHardcore(), par5WorldType, 256);
diff -r old/minecraft/net/minecraft/src/AnvilChunkLoader.java new/minecraft/net/minecraft/src/AnvilChunkLoader.java
325c325
< byte var7 = 16;
> byte var7 = (byte)(par1World.getHeight()>>4); // Max number of chunks pieces
diff -r old/minecraft/net/minecraft/src/BlockLilyPad.java new/minecraft/net/minecraft/src/BlockLilyPad.java
81c81
< return par3 >= 0 && par3 < 256 ? par1World.getBlockMaterial(par2, par3 - 1, par4) == Material.water && par1World.getBlockMetadata(par2, par3 - 1, par4) == 0 : false;
> return par3 >= 0 && par3 < par1World.getHeight() ? par1World.getBlockMaterial(par2, par3 - 1, par4) == Material.water && par1World.getBlockMetadata(par2, par3 - 1, par4) == 0 : false;
diff -r old/minecraft/net/minecraft/src/BlockMushroom.java new/minecraft/net/minecraft/src/BlockMushroom.java
97c97
< if (par3 >= 0 && par3 < 256)
> if (par3 >= 0 && par3 < par1World.getHeight())
diff -r old/minecraft/net/minecraft/src/ChunkCache.java new/minecraft/net/minecraft/src/ChunkCache.java
6a7
> private int worldHeight;
23a25
> this.worldHeight = this.worldObj.getHeight();
72c74
< else if (par2 >= 256)
> else if (par2 >= this.worldHeight)
198c200
231c233
315c317
< if (par3 >= 256)
> if (par3 >= this.worldHeight)
317c319
< par3 = 255;
> par3 = this.worldHeight-1;
320c322
< if (par3 >= 0 && par3 < 256 && par2 >= -30000000 && par4 >= -30000000 && par2 < 30000000 && par4 <= 30000000)
> if (par3 >= 0 && par3 < this.worldHeight && par2 >= -30000000 && par4 >= -30000000 && par2 < 30000000 && par4 <= 30000000)
385c387
< if (par3 >= 256)
387c389
< par3 = 255;
390c392
407c409
< return 256;
> return this.worldHeight;
diff -r old/minecraft/net/minecraft/src/Chunk.java new/minecraft/net/minecraft/src/Chunk.java
92c92
< this.storageArrays = new ExtendedBlockStorage[16];
> this.storageArrays = new ExtendedBlockStorage[par1World.getHeight() >> 4];
1206c1206
< if (par2 >= 256)
> if (par2 >= this.worldObj.getHeight())
1208c1208
< par2 = 255;
> par2 = this.worldObj.getHeight()-1;
1232c1232
< public void fillChunk(byte[] par1ArrayOfByte, int par2, int par3, boolean par4)
> public void fillChunk(byte[] par1ArrayOfByte, long par2, long par3, boolean par4)
diff -r old/minecraft/net/minecraft/src/DedicatedServer.java new/minecraft/net/minecraft/src/DedicatedServer.java
153a154
> /* Note: this gets ignored/overridden by worldInfo.getHeight() */
diff -r old/minecraft/net/minecraft/src/DemoWorldServer.java new/minecraft/net/minecraft/src/DemoWorldServer.java
8c8
< public static final WorldSettings demoWorldSettings = (new WorldSettings(demoWorldSeed, EnumGameType.SURVIVAL, true, false, WorldType.DEFAULT)).enableBonusChest();
> public static final WorldSettings demoWorldSettings = (new WorldSettings(demoWorldSeed, EnumGameType.SURVIVAL, true, false, WorldType.DEFAULT, 256)).enableBonusChest();
diff -r old/minecraft/net/minecraft/src/EntityFallingSand.java new/minecraft/net/minecraft/src/EntityFallingSand.java
170c170
< else if (this.fallTime > 100 && !this.worldObj.isRemote && (var2 < 1 || var2 > 256) || this.fallTime > 600)
> else if (this.fallTime > 100 && !this.worldObj.isRemote && (var2 < 1 || var2 > this.worldObj.getHeight()) || this.fallTime > 600)
diff -r old/minecraft/net/minecraft/src/EntityPlayerMP.java new/minecraft/net/minecraft/src/EntityPlayerMP.java
205c205
< var8.addAll(((WorldServer)this.worldObj).getAllTileEntityInBox(var9.chunkXPos * 16, 0, var9.chunkZPos * 16, var9.chunkXPos * 16 + 16, 256, var9.chunkZPos * 16 + 16));
> var8.addAll(((WorldServer)this.worldObj).getAllTileEntityInBox(var9.chunkXPos * 16, 0, var9.chunkZPos * 16, var9.chunkXPos * 16 + 16, this.worldObj.getHeight(), var9.chunkZPos * 16 + 16));
diff -r old/minecraft/net/minecraft/src/GuiCreateWorld.java new/minecraft/net/minecraft/src/GuiCreateWorld.java
260c260
< WorldSettings var6 = new WorldSettings(var2, var8, this.generateStructures, this.isHardcore, WorldType.worldTypes[this.worldTypeId]);
> WorldSettings var6 = new WorldSettings(var2, var8, this.generateStructures, this.isHardcore, WorldType.worldTypes[this.worldTypeId], 256);
diff -r old/minecraft/net/minecraft/src/IntegratedServer.java new/minecraft/net/minecraft/src/IntegratedServer.java
29d28
< this.setBuildLimit(256);
32a32
> this.setBuildLimit(1024);
diff -r old/minecraft/net/minecraft/src/NetClientHandler.java new/minecraft/net/minecraft/src/NetClientHandler.java
166c166
< this.worldClient = new WorldClient(this, new WorldSettings(0L, par1Packet1Login.gameType, false, par1Packet1Login.hardcoreMode, par1Packet1Login.terrainType), par1Packet1Login.dimension, par1Packet1Login.difficultySetting, this.mc.mcProfiler, this.mc.getLogAgent());
> this.worldClient = new WorldClient(this, new WorldSettings(0L, par1Packet1Login.gameType, false, par1Packet1Login.hardcoreMode, par1Packet1Login.terrainType, par1Packet1Login.worldHeight), par1Packet1Login.dimension, par1Packet1Login.difficultySetting, this.mc.mcProfiler, this.mc.getLogAgent());
574c574
< this.worldClient.invalidateBlockReceiveRegion(par1Packet51MapChunk.xCh << 4, 0, par1Packet51MapChunk.zCh << 4, (par1Packet51MapChunk.xCh << 4) + 15, 256, (par1Packet51MapChunk.zCh << 4) + 15);
> this.worldClient.invalidateBlockReceiveRegion(par1Packet51MapChunk.xCh << 4, 0, par1Packet51MapChunk.zCh << 4, (par1Packet51MapChunk.xCh << 4) + 15, this.worldClient.getHeight(), (par1Packet51MapChunk.zCh << 4) + 15);
586c586
< this.worldClient.markBlockRangeForRenderUpdate(par1Packet51MapChunk.xCh << 4, 0, par1Packet51MapChunk.zCh << 4, (par1Packet51MapChunk.xCh << 4) + 15, 256, (par1Packet51MapChunk.zCh << 4) + 15);
> this.worldClient.markBlockRangeForRenderUpdate(par1Packet51MapChunk.xCh << 4, 0, par1Packet51MapChunk.zCh << 4, (par1Packet51MapChunk.xCh << 4) + 15, this.worldClient.getHeight(), (par1Packet51MapChunk.zCh << 4) + 15);
871c871
< this.worldClient = new WorldClient(this, new WorldSettings(0L, par1Packet9Respawn.gameType, false, this.mc.theWorld.getWorldInfo().isHardcoreModeEnabled(), par1Packet9Respawn.terrainType), par1Packet9Respawn.respawnDimension, par1Packet9Respawn.difficulty, this.mc.mcProfiler, this.mc.getLogAgent());
> this.worldClient = new WorldClient(this, new WorldSettings(0L, par1Packet9Respawn.gameType, false, this.mc.theWorld.getWorldInfo().isHardcoreModeEnabled(), par1Packet9Respawn.terrainType, this.mc.theWorld.getHeight()), par1Packet9Respawn.respawnDimension, par1Packet9Respawn.difficulty, this.mc.mcProfiler, this.mc.getLogAgent());
1173c1173
< this.worldClient.invalidateBlockReceiveRegion(var3 << 4, 0, var4 << 4, (var3 << 4) + 15, 256, (var4 << 4) + 15);
> this.worldClient.invalidateBlockReceiveRegion(var3 << 4, 0, var4 << 4, (var3 << 4) + 15, this.worldClient.getHeight(), (var4 << 4) + 15);
1185c1185
< this.worldClient.markBlockRangeForRenderUpdate(var3 << 4, 0, var4 << 4, (var3 << 4) + 15, 256, (var4 << 4) + 15);
> this.worldClient.markBlockRangeForRenderUpdate(var3 << 4, 0, var4 << 4, (var3 << 4) + 15, this.worldClient.getHeight(), (var4 << 4) + 15);
diff -r old/minecraft/net/minecraft/src/NetServerHandler.java new/minecraft/net/minecraft/src/NetServerHandler.java
394c394
< if (var5 >= this.mcServer.getBuildLimit())
> if (var5 >= var2.getHeight())
440a441
> int worldHeight = var2.worldInfo.getHeight();
451c452
< else if (par1Packet15Place.getYPosition() >= this.mcServer.getBuildLimit() - 1 && (par1Packet15Place.getDirection() == 1 || par1Packet15Place.getYPosition() >= this.mcServer.getBuildLimit()))
> else if (par1Packet15Place.getYPosition() >= worldHeight - 1 && (par1Packet15Place.getDirection() == 1 || par1Packet15Place.getYPosition() >= worldHeight))
453c454
< this.playerEntity.playerNetServerHandler.sendPacketToPlayer(new Packet3Chat("" + EnumChatFormatting.GRAY + "Height limit for building is " + this.mcServer.getBuildLimit()));
> this.playerEntity.playerNetServerHandler.sendPacketToPlayer(new Packet3Chat("" + EnumChatFormatting.GRAY + "Height limit for building is " + worldHeight));
diff -r old/minecraft/net/minecraft/src/Packet1Login.java new/minecraft/net/minecraft/src/Packet1Login.java
22c22
< public byte worldHeight;
> public int worldHeight;
36c36
< this.worldHeight = (byte)par7;
> this.worldHeight = (int)par7;
61c61
< this.worldHeight = par1DataInputStream.readByte();
> this.worldHeight = par1DataInputStream.readByte()<<4;
82c82
< par1DataOutputStream.writeByte(this.worldHeight);
> par1DataOutputStream.writeByte(this.worldHeight>>4);
diff -r old/minecraft/net/minecraft/src/Packet51MapChunkData.java new/minecraft/net/minecraft/src/Packet51MapChunkData.java
6,7c6,7
< public int chunkExistFlag;
< public int chunkHasAddSectionFlag;
> public long chunkExistFlag; // Longs to allow more than 32 chunk sections
> public long chunkHasAddSectionFlag;
diff -r old/minecraft/net/minecraft/src/Packet51MapChunk.java new/minecraft/net/minecraft/src/Packet51MapChunk.java
21c21
< public int yChMin;
> public long yChMin;
26c26
< public int yChMax;
> public long yChMax;
43c43
< private static byte[] temp = new byte[196864];
> private static byte[] temp = new byte[196864*4]; //up to 1K-tall maps
50c50
< public Packet51MapChunk(Chunk par1Chunk, boolean par2, int par3)
> public Packet51MapChunk(Chunk par1Chunk, boolean par2, long par3)
161c161
< public static Packet51MapChunkData getMapChunkData(Chunk par0Chunk, boolean par1, int par2)
> public static Packet51MapChunkData getMapChunkData(Chunk par0Chunk, boolean par1, long par2)
diff -r old/minecraft/net/minecraft/src/Packet56MapChunks.java new/minecraft/net/minecraft/src/Packet56MapChunks.java
15,16c15,16
< public int[] field_73590_a;
< public int[] field_73588_b;
> public long[] field_73590_a;
> public long[] field_73588_b;
39,40c39,40
< this.field_73590_a = new int[var2];
< this.field_73588_b = new int[var2];
> this.field_73590_a = new long[var2];
> this.field_73588_b = new long[var2];
48c48
< Packet51MapChunkData var6 = Packet51MapChunk.getMapChunkData(var5, true, 65535);
> Packet51MapChunkData var6 = Packet51MapChunk.getMapChunkData(var5, true, -1L); //2^64-1
91,92c91,92
124,125c124,125
< this.field_73590_a[var6] = par1DataInputStream.readShort();
< this.field_73588_b[var6] = par1DataInputStream.readShort();
> this.field_73590_a[var6] = par1DataInputStream.readLong();
> this.field_73588_b[var6] = par1DataInputStream.readLong();
164,165c164,165
< par1DataOutputStream.writeShort((short)(this.field_73590_a[var2] & 65535));
< par1DataOutputStream.writeShort((short)(this.field_73588_b[var2] & 65535));
> par1DataOutputStream.writeLong((this.field_73590_a[var2] & (-1L)));
> par1DataOutputStream.writeLong((this.field_73588_b[var2] & (-1L)));
diff -r old/minecraft/net/minecraft/src/PlayerInstance.java new/minecraft/net/minecraft/src/PlayerInstance.java
14c14
< private int field_73260_f;
> private long field_73260_f;
diff -r old/minecraft/net/minecraft/src/RConThreadClient.java new/minecraft/net/minecraft/src/RConThreadClient.java
58c58
< if (10 <= var2)
> if (10 > var2)
60,61c60,61
< byte var3 = 0;
< int var4 = RConUtils.getBytesAsLEInt(this.buffer, 0, var2);
> return;
63,66c63,64
< if (var4 != var2 - 4)
< return;
> byte var3 = 0;
67a66,67
> if (var4 == var2 - 4)
diff -r old/minecraft/net/minecraft/src/RenderGlobal.java new/minecraft/net/minecraft/src/RenderGlobal.java
308c308
< int var1;
> int var1, varChunkTall;
323a324,329
> varChunkTall = this.theWorld.getHeight();
> if (varChunkTall > var1)
> varChunkTall = var1;
326c332
< this.renderChunksTall = 16;
> this.renderChunksTall = var1 / 16 + 1;
diff -r old/minecraft/net/minecraft/src/WorldClient.java new/minecraft/net/minecraft/src/WorldClient.java
140c140
< this.markBlockRangeForRenderUpdate(par1 * 16, 0, par2 * 16, par1 * 16 + 15, 256, par2 * 16 + 15);
> this.markBlockRangeForRenderUpdate(par1 * 16, 0, par2 * 16, par1 * 16 + 15, this.getHeight(), par2 * 16 + 15);
diff -r old/minecraft/net/minecraft/src/WorldInfo.java new/minecraft/net/minecraft/src/WorldInfo.java
49a50,52
> /** Height of the map. */
69a73
> this.worldHeight = 256;
137a142,147
> if (par1NBTTagCompound.hasKey("worldHeight"))
> this.worldHeight = par1NBTTagCompound.getInteger("worldHeight");
> } else {
> this.worldHeight = 256; /* Default value goes HERE for worldHeight */
184a195
> this.worldHeight = par1WorldSettings.getHeight();
210a222
> this.worldHeight = par1WorldInfo.worldHeight;
257a270
> par1NBTTagCompound.setInteger("worldHeight", this.worldHeight);
446a460,475
> * Returns the height of the world, in voxels.
> public int getHeight()
> * Defines the height of the world, in voxels.
> public void setHeight(int par1)
> this.worldHeight = par1;
diff -r old/minecraft/net/minecraft/src/World.java new/minecraft/net/minecraft/src/World.java
297c297
> else if (par2 >= this.getHeight())
357c357
< return par2 >= 0 && par2 < 256 ? this.chunkExists(par1 >> 4, par3 >> 4) : false;
> return par2 >= 0 && par2 < this.getHeight() ? this.chunkExists(par1 >> 4, par3 >> 4) : false;
373c373
< if (par5 >= 0 && par2 < 256)
> if (par5 >= 0 && par2 < this.getHeight())
436c436
503c503
533c533
788c788
< if (par2 >= 256)
790c790
< par2 = 255;
> par2 = this.getHeight()-1;
856c856
< if (par2 >= 256)
858c858
< par2 = 255;
937c937
< if (par3 >= 256)
> if (par3 >= this.getHeight())
1004c1004
< if (par3 >= 256)
1006c1006
< par3 = 255;
> par3 = this.getHeight()-1;
1040c1040
< if (par3 < 256)
> if (par3 < this.getHeight())
2619c2619
< if (par2 >= 0 && par2 < 256)
> if (par2 >= 0 && par2 < this.getHeight())
3092c3092
< if (par2 >= 0 && par2 < 256 && this.getSavedLightValue(EnumSkyBlock.Block, par1, par2, par3) < 10)
> if (par2 >= 0 && par2 < this.getHeight() && this.getSavedLightValue(EnumSkyBlock.Block, par1, par2, par3) < 10)
3150c3150
4094c4094
< return 256;
> return this.worldInfo.getHeight();
4102c4102
< return this.provider.hasNoSky ? 128 : 256;
> return this.provider.hasNoSky ? 128 : this.getHeight();
diff -r old/minecraft/net/minecraft/src/WorldRenderer.java new/minecraft/net/minecraft/src/WorldRenderer.java
168a169,171
> if (var15 > 255 && var18 != 0) {
> System.err.printf("Getting nonzero block %d at (%d,%d,%d)\n", var18, var17, var15, var16);
diff -r old/minecraft/net/minecraft/src/WorldSettings.java new/minecraft/net/minecraft/src/WorldSettings.java
27c27,30
< public WorldSettings(long par1, EnumGameType par3EnumGameType, boolean par4, boolean par5, WorldType par6WorldType)
> /** Contains the world height, in blocks/voxels. */
> public WorldSettings(long par1, EnumGameType par3EnumGameType, boolean par4, boolean par5, WorldType par6WorldType, int worldHeight)
34a38,39
> this.worldHeight = worldHeight;
> System.err.printf("New world has height %d\n", this.worldHeight);
39c44
< this(par1WorldInfo.getSeed(), par1WorldInfo.getGameType(), par1WorldInfo.isMapFeaturesEnabled(), par1WorldInfo.isHardcoreModeEnabled(), par1WorldInfo.getTerrainType());
> this(par1WorldInfo.getSeed(), par1WorldInfo.getGameType(), par1WorldInfo.isMapFeaturesEnabled(), par1WorldInfo.isHardcoreModeEnabled(), par1WorldInfo.getTerrainType(), par1WorldInfo.getHeight());
130a136,152
> * Gets the worldHeight
> * Sets the worldHeight
> public void setHeight(int worldHeight)
