My friend and I are developing a program in C, and I'm trying to implement support for multiple languages. We're trying to create a text RPG, like Zork, and we're trying to make it customizable by loading in data from external plain-text files. As an example, the file containing data for the first room in English is located at res/en/room/001.txt. I've tried the following code, but it does not work and exits with status 255.
#include <stdio.h>
#include <stdlib.h>
char* roomFileName;
void setLang(char* lang)
    roomFileName[4] = lang[0];
    roomFileName[5] = lang[1];
void loadRoom(int roomNumber)
    char roomString[5];
    sprintf(roomString, "%03d", roomNumber);
    roomFileName[12] = roomString[0];
    roomFileName[13] = roomString[1];
    roomFileName[14] = roomString[2];
    FILE *roomFile;
    roomFile = fopen(roomFileName, "r");
    // Handle data
    fclose(roomFile);
int main()
    setLang("en");
    roomFileName = "res/xx/room/yyy.txt";
    loadRoom(1);
    // This is just to let me see if anything actually worked if the program exits properly
    printf("%s",roomFileName);
    return 0;
Can anybody help me see what might be the issue with this?
You're really not supposed to modify string constants (they're called constants for a reason). It might be generally better if you define a char array to hold the filename and do something like sprintf(filename, "res/%s/room/%03d.txt", lang, roomNumber);
Indeed, modifying a string constant like that is shady at best and a segfault at worst. Calc84's suggestion is pretty much the way you should do that. You can either use a statically-reserved string like char* roomFileName[255], or malloc() space for the string.
They're only constant if declared const, which these aren't. It's fine.
Oh, it's a pointer rather than a buffer. Yeah, that's bad. That should produce a few warnings when compiled.
Agreed, this is probably the cleanest way to do it.
Was I incorrect to be under the impression that some compilers might put string constants on memory pages marked read-only, no write/execute?
Edited after I noticed it's a pointer. He's discarding the implicit const qualifier from the string literal, so that should emit a warning (and it may do the wrong thing, depending on the platform).
Certainly such a thing on Prizm would be an attempted write to Flash, whatever the consequences of such an action.
Thanks, guys. I've been working with C++ a bit recently and have gotten used to using the string class, but I've been wanting to keep this in C to make sure I can grasp the concepts. I guess it's pretty clear I didn't make enough of an effort to understand arrays and pointers. Rolling Eyes
