- [New Device] HP200LX
- 10 Mar 2013 02:19:47 pm
- Last edited by Tom on 10 Mar 2013 02:23:15 pm; edited 2 times in total
I found my old HP200LX and got it out and had some fun.
I got the specs on it
Hardware-
CPU: Intel 80186 7.91 Mhz
RAM: 1 to 4 MB of memory, of which 640 KB is RAM and the rest can be used for expanded memory (EMS) or memory-based storage space.
Ports-
16 bit Type II PCMCIA Slot x1
Serial Port x1
SIR compatible Infrared Transceiver x1
Battery charging port +(-)
Screen-
CGA Compatible 4 shade grayscale 640x200 screen (No Backlight)
Software-
HP LX Palmtop Software
DOS 5.0
BASIC Interpreter (Select models i think, mine has it but my friends does not )
Lotus 1-2-3 Spreadsheet
Lotus cc:Mail
Calculator (Math, Equation solver and many many more functions. Probably graphing too.)
Hearts and Bones
Lair of Squid
Power-
Requires 2 AA batteries to run (With options to use Rechargeable or Alkaline or even a Power Supply.
The HP 200LX can run virtually any program that would run on a full-size PC compatible computer as long as the code is written for the Intel 8086, 8088 or 80186 CPU and can run using CGA graphics. It can also run programs written for the 80286 CPU, provided they do not require the use of protected memory.
Pictures:
Top
Left Side
Left Side with PCMCIA removed
Front
Right Side IR Port (Black) Serial port and Power Supply Port +(-)
Hardware-
Ports-
Serial Port x1
Screen-
Software-
DOS 5.0
Lotus cc:Mail
Hearts and Bones
Lair of Squid
Power-
Pictures:
Top
Left Side
Front
