Okay. Is there adapters for that?
Edited by Kerm: image changed to link:
http://i.imgur.com/vfOQgwx.jpg
Here's a comparison of the plugs. From left to right: TI's connector from the old unit-to-unit link, a 3.5mm headphone plug, and a 2.5mm connector from an old PDA.
There are adapters available, but it is cheaper to get a TI cable off of eBay than it is to get two adapters and a 3.5mm cable. You may be able to use a unit-to-unit link and a TI-83 Plus from a school, if possible or necessary.
That was a reeeeeaally big pic! But thanks for the help, I think my electronics teacher might have a 2.5 mm cable.
OH MY GIRD!!! Does NOBODY in America have 2.5 mm cables?! I've been looking everywhere and can't find one!
UPDATE!! I borrowed a ti calc-to-calc cable and plugged it into a class calc. I took out a battery from mine and put it back in while holding delete. The install screen came up (jumbled), and on the class calc I selected send OS. After about 5 minutes of a jumbled "Receiving..." screen, the working calc said "Done" and mine turned off. When I turned it back on, it still didn't work!!! I heard there is a reset button near the backup battery, is that true?
No, that's not true. It sounds like your calculator is working fine now, but it has the LCD cable issue that remains unrepaired. I have heard very few reports of the Flash chip going bad that easily.
ghest1138 wrote:
do i have to open it now?
Yup. But "LCD Ribbon Cable Failure" is such a common topic on Cemetech now that the best tutorial you'll find here will tell you exactly what to do.
Visit Betafreak Games: http://www.betafreak.com
Help Me Pay for College:
- Sign up for Fastweb through my referal link!
Don't forget about my methods with conductive ink. It may be less durable than soldering, but it works for people like myself that are horrible at soldering. It can also flow through the PCB's holes or around the edge if necessary.
http://www.cemetech.net/forum/viewtopic.php?p=196634#196634 for a terrible example, a calc with a burned ribbon cable and a trace ripped out.
sorry for the double post. Unfortunately, my calc was mistaken for garbage and thrown away ☹️ If I still had it, though, I might be able to have done some soldering, but I think the ink would have been a bit easier, seeing as how close together the contacts are( for a noob, at least). I've seen conductive ink(or maybe it was graphite) used for the whole keypad circuit on a cheap desktop calc. Now my problem is how to get a new calc ☹️
Oh no, that's terrible! Quote:
Well, you can find TI-83+s for extremely cheap on eBay, and broken ones even cheaper. That might be a good place to start; you could also check out thrift stores and pawn shops in your area.
also unfortunately, I have no money as of now. I've been bumming electronics from people at school for quite some time now, though( Almost got a gameboy color for free!) My engineering teacher has about 10 of them, but I seriously doubt he would give one away for free (I certainly wouldn't!)
I just recieved an 83+ from a friend who was upgrading to an 84+.Borrowed a link cable and got DCS 7, Mimas ide, and Grammer!
» Goto page Previous 1, 2
Page 2 of 2
