This code won't run because of indents or something.
Help!
from System.Net.Sockets import *
from System.Text import *
class Module1(object):
         def __init__(self):
                 self._clientsList = Hashtable()
         def Main(self):
                 serverSocket = TcpListener(8888)
                 serverSocket.Start()
                 self.msg("Chat Server Started ....")
                 counter = 0
                 while (True):
                         counter += 1
                         clientSocket = serverSocket.AcceptTcpClient()
                         bytesFrom = Array.CreateInstance(Byte, 10024)
                         networkStream = clientSocket.GetStream()
                         networkStream.Read(bytesFrom, 0, clientSocket.ReceiveBufferSize)
                         dataFromClient = System.Text.Encoding.ASCII.GetString(bytesFrom)
                         dataFromClient = dataFromClient.Substring(0, dataFromClient.IndexOf("$"))
                         self.clientsList(dataFromClient) = clientSocket
                         self.broadcast(dataFromClient + " Joined ", dataFromClient, False)
                         self.msg(dataFromClient + " Joined chat room ")
                         client = handleClinet()
                         client.startClient(clientSocket, dataFromClient, self._clientsList)
                 clientSocket.Close()
                 serverSocket.Stop()
                 self.msg("exit")
                 Console.ReadLine()
         def msg(self, mesg):
                 mesg.Trim()
                 Console.WriteLine(" >> " + mesg)
         def broadcast(self, msg, uName, flag):
                 enumerator = clientsList.GetEnumerator()
                 while enumerator.MoveNext():
                         Item = enumerator.Current
                         broadcastSocket = Item.Value
                         broadcastStream = broadcastSocket.GetStream()
                         if flag == True:
                                 broadcastBytes = Encoding.ASCII.GetBytes(uName + " says : " + msg)
                         else:
                                 broadcastBytes = Encoding.ASCII.GetBytes(msg)
                         broadcastStream.Write(broadcastBytes, 0, broadcastBytes.Length)
                         broadcastStream.Flush()
class handleClinet(object):
                 def __init__(self):
                    def startClient(self, inClientSocket, clineNo, cList):
                            self._clientSocket = inClientSocket
                            self._clNo = clineNo
                            self._clientsList = cList
                            ctThread.Start()
                 def doChat(self): #Dim infiniteCounter As Integer
                         requestCount = 0
                         while (True):
                                 try:
                                         requestCount = requestCount + 1
                                         networkStream = self._clientSocket.GetStream()
                                         networkStream.Read(bytesFrom, 0, self._clientSocket.ReceiveBufferSize)
                                         self.msg("From client - " + self._clNo + " : " + dataFromClient)
                                         rCount = Convert.ToString(requestCount)
                                         self.broadcast(dataFromClient, self._clNo, True)
                                  except Exception, ex:
                                           self.MsgBox(ex.ToString)
                               finally:
A nice thing about Python is it tells you exactly what is wrong. What error message do you receive?
File "irc.py", line 64
IndentationError: unindent does not match any outer indentation level
The try and its matching except need to be at the same indentation level. The space-based tabbing on that file is killing me; you should replace it with zero tabs for the first level, one tab for the second level, two tabs for the third, etc. That would avoid this issue. You have except...: pushed out by one more space than try:.
Got it. Thanks. Copying code from lynx isn't the best 😛
Edit: Now I get a new error
File "irc.py", line 66
    finally:
SyntaxError: invalid syntax
Yeah, I'll say. If you're stuck on the command line, use wget to grab the raw file, if possible.
Edit: You have no code under the finally. If you don't have any code to be run in the finally part of a try/catch/finally block in Python, just leave out the finally. Alternatively, you can use the keyword "pass" wherever you need a command but have no command you want to run. It's a no-op.
I keep getting erros. I think I'll just give up on this code. Feel free to delete this thread.
Don't have that short of an attention span! Persevere, learn from errors, go through the sweat and tears of figuring out what's wrong. 😛 You'll never get too far in programming if you give up whenever something doesn't work for five minutes. I spent six years in between writing the first version of the CALCnet interrupt and getting it to work.
Haha. It's not my own code. I think i'll just go back to trying to get pIRCd to work...
