(1) There is no wait function. You could put ticks() in a loop if you want a timed wait, or use keyMenu() to pause until any key is pressed.
(2) There are formulae for that out on the internet. I don't know any of those off the top of my head.
(3) Are you using v0.1 or v0.1.1? If just 0.1, upgrade ASAP. It fixes keyMenu() and adds the makeColor() function directly in ZMG.
OK, thanks Smile
I checked, nothing in lua.
Ah, OK, will do right now Smile
Well no, I wouldn't expect so, but I'm sure there are general algorithms or Java or C or Python code that you could easily port. Smile
Oh, ok will check Smile
The first answer in this StackOverflow thread seems like a decent solution to me:
http://stackoverflow.com/questions/1692184/converting-epoch-time-to-real-date-time
Would this be a good port?
C++ code:
void DateTime::splitTicks(time_t time) {
    seconds = time % 60;
    time /= 60;
    minutes = time % 60;
    time /= 60;
    hours = time % 24;
    time /= 24;
    year = DateTime::reduceDaysToYear(time);
    month = DateTime::reduceDaysToMonths(time,year);
    day = int(time);
int DateTime::reduceDaysToYear(time_t &days) {
    int year;
    for (year=1970;days>daysInYear(year);year++) {
        days -= daysInYear(year);
    return year;
int DateTime::reduceDaysToMonths(time_t &days,int year) {
    int month;
    for (month=0;days>daysInMonth(month,year);month++)
        days -= daysInMonth(month,year);
    return month;
Lua Code:
function splitTicks( time_t, time )
   seconds = time % 60
   time = time / 60
   minutes = time % 60
   time = time / 60
   hours = time % 24
   time = time / 24
   year = reduceDaysToYear( time )
   month = reduceDaysToMonths( time, year )
   day = math.floor( time )
end
function reduceDaysToYear( time_t, days )
   math.floor( year )
   for year=1970, daysInYear( year ), 1 do
      days = days-daysInYear( year )
   end
   return year
end
function reduceDaysToMonths( time_t, days, math.floor( year ))
   math.floor( month )
   for month=0, daysInMonth( month, year ), 1 do
      days = days-daysInMonth( month, year )
   end
   return month
end
Please tell me if any of that is wrong. Smile
I have no C++ knowledge and only a small amount of lua knowledge.
Unfortunately that's not quite right. time_t is a type (like string, int, float, etc), not an argument. I'll see if I can bang out a bit of code tomorrow to help you; feel free to ping me about it if I forget.
OK, this seems to me like a garbage collecting problem. If I try to run a large-ish program two times in a row, this happens:
not enough memory
stack traceback:
    [C]: in function 'run'
    stdin:1: in main chunk
    [C]: in ?
not enough memory
stack traceback:
    sdtin:1: in main chunk
    [C]: in ?
It could also be insufficiently-aggressive garbage collecting, but the problem could be fixed if your global variables were tagged with local, as far as I understand Lua scoping.
not enough memory
stack traceback:
    [C]: in ?
The same thing happens with bloxorz.
Yeah I know, but spence's program does not use local vars, and for some reason it does not seem standard in non-luaFX circles not to use global vars...
When you run it twice in a row, or when you run a very large program once? If the former, then yes, something needs to be adjusted (not the least of which is the Prizm's baffling malloc() behavior.
for me it has only happened when I try to run it twice in a row. Or when I exit with AC/on.
OK, also don't know if this is a bug or not.
If you do not use a getkey function then you cannot break from loops with ac/on.
For instance:
while 1
print("hello moon")
end
Will loop forever until you press the reset button or pop a battery.
That's a glitch; it should be possible to break out of that. When I get back to LuaZM and work on the IO library, I'll see if I can track that down.
BUG REPORT
Version: 0.1.1beta
Subject: zmg.drawText sometimes freezes when drawing off screen
Reproducible: Yes
Steps to reproduce:
Run this code:
drawText(1, 20, "by TakeFlight Productions (flyingfisch)", color.fg, color.bg)
Notes:
It has happened with other strings of text as well, but some work when drawing off screen fine. Don't know what the problem is...
Can you please try with a shorter string closer to the edge of the screen, and see if you can replicate it that way?
This code freezes my calc... maybe someone else would like to test it too?
local keyDirectPoll = zmg.keyDirectPoll
local keyDirect = zmg.keyDirect
local drawText = zmg.drawText
local fastCopy = zmg.fastCopy
local key = {F1=79, F2=69, F3=59, F4=49, F5=39, F6=29, Alpha=77, Exit=47,
Optn=68, Up=28, Down=37, Left=38, Right=27, EXE=31}
local text = {x=300, y=1, string="test"}
while exit ~= 1 do
   if keyDirect(key.Exit) > 0 then exit = 1
      elseif keyDirect(key.Left) > 0 then text.x = text.x - 1
      elseif keyDirect(key.Right) > 0 then text.x = text.x + 1
   end
   drawText(text.x, text.y, text.string, 0x0000, 0xFFFF)
   fastCopy()
end
I tested it out and it did the same thing for me.
Whenever I try to use a masked sprite, it appears all weird looking. Can someone test this too and see if it is a bug?
» Goto page Previous  1, 2, 3, 4, 5, 6  Next
Page 3 of 6
