Okay, my calc is being slightly freakish now
, For some reason, everytime I try to edit any program, Axe, Asm or Ti-Basic. I can run any existing programs just fine though.
Now when I try to edit a program, it inverts colors, shows a bunch of garbled text, waits for some time, then turns off and clears all RAM.
I tried removing all my apps, as well as re-installing the OS (2.55MP)
The calc is a Ti-84+SE
What's wrong?
I've heard that Axe has some bugs that can cause Flash corruption, so you might want to try doing a full Flash clear, if you haven't already. You might also want to do a Flash test with Mode-ALPHA-S.
How do I do the full flash clear? Also when I run the flash test: I get the following: `27434` and followed by a RAM clear, is that right?
[2nd][+][7][<-][Enter][2]
(Enter memory menu, select ALL tab, select All Memory, and then Reset.)
Thanks, it solved the issue!
Excellent! And now you know what to do in the future if Axe starts running rampant over your Flash. I'm actually surprised to hear that that issue is still there; I think it's a year or more old at this point.
Yes, it is strange. This was present in 1.0.X versions but should have been fixed. Maybe this should be reported to Quigibo ?
