- [PP] ZITU
- 09 Aug 2011 08:01:47 am
- Last edited by tifreak8x on 29 Jun 2012 01:32:42 pm; edited 2 times in total
This is just the lines of code I am using to make the items work; Click Here to discuss any of the code snippets in the posts below.
Admins: Please don't post in this topic so I can keep it clean flowing to show the item code off in the order they are in the calc. It helps me keep a backup of the code incase something goes wrong. Thakns 🙂
Antidote:
Antidote:
If Tmin>0 and Z=1:Then:If L1(44)!=2:Then:ClrDraw:RecallPic Pic1:Text(47,4,"ANTIDOTE INEFFECTIVE":prgmZWT:For(F,4,14:Line(4,F,90,F,0:End:1->W:End:If L1(44)=2:Then:ClrDraw:RecallPic Pic1:"rowSwap(ZPNA"->Str0:0->theta:L1(43:prgmZCE:0->L1(44:Text(47,4,Str9," WAS CURED":Text(53,4,"OF POISON!":Text(29,79," ":prgmZWT:For(F,4,14:Line(4,F,90,F,0:End:StorePic Pic1:1.5->W:End:End:If iPart(W)=1:Return:If (Tmin>0 and Z>1) or (Tmin=0 and Z>0:Then:expr("|LP"+sub("123456",|LPRTY(iPart(Z)),1)+"(44"->K:If K!=2:Then:For(F,0,17:Line(0,F,94,F,0:End:"0ZBD":prgmZRS:{94,0,3,15:prgmTEMP:prgmZC1:Text(47,4,"ANTIDOTE INEFFECTIVE":prgmZWT:ClrDraw:1->W:Return:End:If K=2:Then:4->theta:"ZTMP2"->Str0:prgmZCE:"|LP"+sub("123456",|LPRTY(iPart(Z)),1->Str7:3->theta:prgmZCE:"UnArchive "+Str7+":0"+sub(Str9,1,1)+Str7+"(44"->Str9:1->theta:"ZTMP2"->Str0:1:prgmZCE:prgmZTMP2:6->theta:prgmZCE:expr(Str7+"(43"->PMT:0->theta:"rowSwap(ZPNA"->Str0:PMT:prgmZCE:For(F,0,17:Line(0,F,94,F,0:End:"0ZBD":prgmZRS:{94,0,3,15:prgmTEMP:prgmZC1:"rowSwap(ZPNA"->Str0:0->theta:expr(Str7+"(43":prgmZCE:Text(47,4,Str9," WAS CURED":Text(54,4,"OF POISON!":prgmZWT:If Tmin>0:1.5->W:End:End
