As you may know, I am working on a 3D graphing utility for the Casio Prizm graphing calculator. I have it working nicely, short of a few features. Notably, I've been using a camera rotation system whereby pressing one set of arrows adds/subtracts to/from the absolute theta_y, and pressing the other set adds/subtracts to/from the absolute theta_z. For correct rotation, the change in [theta_x, theta_y, theta_z] needs to depend on the current [theta_x, theta_y, theta_z], and I am having a hard time deriving the correct math for it. First, a bit of background:
:: I am defining the rotation for the graph with three angles, theta_x, theta_y, theta_z (or XYZ), applied in order of X, Y, Z. The transform I'm using is called the camera transform (using the camera transform). It's a left-handed transform, with, as I said, an angle order of X, Y, then Z. My code to calculate the camera position looks like this (remember, I want to keep it pointing at the center of the graph, which is usually the three-dimensional origin (0,0,0).):
Next, the math that I use to apply the camera transform to 3D points to be drawn to account for the camera position and heading. (dx, dy, dz) are the remapped coordinates in 3-space:
However, adjusting the camera rotation is proving to be a real problem. I've considered several different approaches:
The code for the last approach is here. It sadly does not work. Any assistance would be greatly appreciated. matan2f is a custom atan2() implementation.
I should mention that I found the algorithm at the end of that here:
http://stackoverflow.com/questions/1251828/calculate-rotations-to-look-at-a-3d-point. Again, thanks in advance for any help, large or small.
costx = mcosf(theta_x); sintx = msinf(theta_x); // 1 0
costy = mcosf(theta_y); sinty = msinf(theta_y); // 1 0
costz = mcosf(theta_z); sintz = msinf(theta_z); //-1 0
float alpha = 0.f, beta = 0.f, gamma = cam_radius;
float alpha_prime = alpha*costy*costz + beta*(costy*sintz) + gamma*(sinty);
float beta_prime = -alpha*(costx*sintz+costz*sintx*sinty) + beta*(costx*costz-sintx*sinty*sintz) + gamma*costy*sintx;
float gamma_prime = alpha*(sintx*sintz-costx*costz*sinty) - beta*(costz*sintx+costx*sinty*sintz) + gamma*costx*costy;
cx = -alpha_prime;
cy = -beta_prime;
cz = -gamma_prime;
// adjust for grid center (ex,ey)
cx += ex;
cy += ey;
float dx = (val_x-cx)*costy*costz + (val_y-cy)*(costy*sintz) + (val_z-cz)*(sinty);
float dy = -(val_x-cx)*(costx*sintz+costz*sintx*sinty) + (val_y-cy)*(costx*costz-sintx*sinty*sintz) + (val_z-cz)*costy*sintx;
float dz = (val_x-cx)*(sintx*sintz-costx*costz*sinty) - (val_y-cy)*(costz*sintx+costx*sinty*sintz) + (val_z-cz)*costx*costy;
- Simply add/subtract pi/8 to/from theta_y/theta_z. This does rotation, but not intuitively.
- Use the camera transform to transform delta theta_y or delta theta_z values into delta_x/y/z angles, and add those to theta_x/y/z. This appears not to work.
- Use the camera cx/cy/cz coordinates, and apply a camera transform of +/- pi/8 in either theta_y or theta_z. Then, use the resulting new coordinates for the camera to work backwards and get the XYZ angles for the vector that joins the origin to that point.
//alpha, beta, gamma are the delta rotation angles
float c1 = mcosf(alpha), c2 = mcosf(beta), c3 = mcosf(gamma);
float s1 = msinf(alpha), s2 = msinf(beta), s3 = msinf(gamma);
//[cxo cyo czo] are the camera coords before inversion/re-centering
float alpha_prime = cxo*c2*c3 + cyo*(c2*s3) + czo*(s2);
float beta_prime = -cxo*(c1*s3+c3*s1*s2) + cyo*(c1*c3-s1*s2*s3) + czo*c2*s1;
float gamma_prime = cxo*(s1*s3-c1*c3*s2) - cyo*(c3*s1+c1*s2*s3) + czo*c1*c2;
theta_x = matan2f( beta_prime, gamma_prime );
if (gamma_prime >= 0) {
theta_y = matan2f( alpha_prime * mcosf(theta_x), gamma_prime );
} else {
theta_y = matan2f( alpha_prime * mcosf(theta_x), -gamma_prime );
theta_z = matan2f( mcosf(theta_x), msinf(theta_x) * msinf(theta_y) );
