Hey,
I got a problem with plotting a function stored in a variable.
For example:
x+2 -> w
Graph w
but this doesn't work. What am i doing wrong or is this even possible?
(TI 89T)
Can I safely assume that you're using a TI-89 here, Timijan? W is a number, not an equation, so you'll be literally storing the value of x plus 2 into w; this means you'll get a horizontal line when you graph it. You instead want to store the equation "x+2" into one of the graph functions and graph that.
You actually aren't storing an equation into that variable, you're actually storing the value of X + 2 into W. Is this in a program, or just in general with the equation inputter/graph button?
@KermMartian indeed i am using TI-89. You managed to replay before i could edit my post Smile
@Ashbad i try to use this in a program.
Based on input data and some derivation function is formed and than i try to graph that function.
Now if i try to put this function in "x+2"-> w and graph w, nothing happens. Graph screen is shown but nothing is drawn. If i try to store it in y1 instead of w it says name is reserved.
So even though i thing what i was doing wrong, i still don't know how to make this work.
Ok, I managed to sole it like this:
x+2->w
string(w)->w
"Define y1(x)="&w->q
expr(q)
DispG
Pause
I wrapped your code in [code] tags, good sir. Yup, that's a good way to do things, although why can't you just directly run the Define command?
I have a similar problem. I want to plot a function (particularly, a polinomial) which depends on the variable t. the polinomial is stored in the variable p, so according to the user's guide I should proceed like this:
graph p, t
But when I do this it gives me an error that says "Undefined Variable". I also tried the solution timijan found but it didn't work.
Any idea?
Thanks in advance
Charlie
Have you tried the obvious solution of checking that p is defined? Are you sure you don't have to put the t in quotes?
The Graph command wants an equation entered exactly the same way it would be entered on the Y= screen. You can either do something like:
Graph x+2,x
to graph x+2. Or, you can define the function in a separate variable:
Define w(x)=x+2
and then:
Graph w(x),x
This syntax should work. Make sure the graphing mode in the Mode screen is set to Function first.
It's weird. If I execute for example:
graph 2*t + 1, t
From the home screen, the calculator plots the function 2*t+1, but if I put it in a program it gives an error saying "Undefined variable".
I solved the problem I had, but I had to do this:
"define pos(t)="&p
graph pos(t),t
Where p is an expression that depends on t and it was previously defined.
graph 2*t + 1, t
Do you happen to have ‘t’ defined as local with the Local command? It seems that this will cause the error. If so, removing it from Local may help.
Travis wrote:
graph 2*t + 1, t
I tried both things (t as local and not local), but none of them worked.
