Okay, so I've had this calculator for a long time, but it was corrupted two years ago. I was running the Omnicalc Font Editor program from ticalc.org (I believe this was it), and it suddenly crashed. Upon removing and re-inserting the battery, I was greeted with a screen full of nonsense. Occasionally, it would fail and overvolt the LCD (blue screen). I cleared archive and re-installed the OS to no avail. I essentially gave up on repairing it. However, recently, I was thinking of how similar the 83+SE and the 84+SE were spec-wise, and I have a newer 84+SE (post-2007, with only 48KB RAM). I thought of how I would be able to do much more if I was using the 83+SE as opposed to its newer variant. That inspired me to try to repair the calculator. I invalidated the OS, and booted it into the full self-test (with archive check). The screen showed things that made decent sense now, and so I decided to re-install OS 1.19. It was difficult to install it, because it continuously shut down when it received power via the link port. In the end, I made it receive by removing a battery and re-inserting it while the link cable was connected on both ends. However, even upon re-install, things were still glitchy. I still experience the issue of the overvolted LCD at times (blue screen).
I was curious if anybody had any ideas as to how I could possibly repair the calculator. Please help if you can.
I'll add screenshots if desired, but I don't think they'd help much. Tell me if I'm wrong.[/url]
