I have downloaded doors 7th edition on my ti-83+ SE, downloaded plenty of programs, but all of them display the answer for a fraction of a second and quit back to doors home screen with no time for me to copy the answer. please help me.
The programs use Output to display the answer then nothing more. If possible, modify them and put "Pause" on a new line after Output.
DoorsCS uses the graph screen, so after a program quits at the HomeScreen DCS quickly switches back to the graph screen and renders itself.
welcome to Cemetech! As I had suggested to you in the chatroom, you coul put a Pause at the end of your programs that you are running, so that they would wait for you to press Enter before exiting. I had thought that DCS waited for you to press a key, but it could have very well been that it waits for a few seconds. You should Introduce Yourself!
can you then please help me or direct me to an interpolation program that might have a pause in ? i am ignorat when it comes to programming :s
Editing it is easy. Would you mind linking us to one of the programs you downloaded so I, or someone, else can show you in this topic?
Right click on the program in DCS and click "Edit", then scroll to the bottom [2nd][Alpha][Down] but hold onto Down. When you reach the bottom, press [Alpha] and then [Prgm][4] (or look in the menu for Pause). Then press [2nd][Mode] to quit. It should work, now.
its not working with me, i have included the url of the program i have downloaded if any of you guys would like to help me =) i would appreciate it !
http://www.ticalc.org/archives/files/fileinfo/174/17449.html
- In DoorsCS7, move the cursor onto the program and press ALPHA (DCS7's version of right-clicking)
- Move the cursor to EDIT (on the bottom of the context menu) and click it
- In the editor that comes up, scroll down and find every Stop command, and for each one:
- With your cursor directly on top of the S in Stop, press 2nd+{INS} (press [2nd], then [DEL]), then press ENTER once to enter a new line before it
- Put your cursor in that blank line, press PRGM > 8:Pause to paste Pause there
- Press 2nd+{QUIT} (press [2nd], then [MODE]) to quit
Hope that's clear enough.
Thanks for helping out this user, everyone. I'm a bit surprised at this report, actually, because Doors CS is designed to pause on the result of a homescreen program if it exits with the homescreen visible and non-blank.
_player1537 wrote:
Could it be because of the Stop statements?
Possible but unlikely, since Doors CS catches Stop and translates it into a sort of absolute Return. I'll have to look at my code and see what's happening. KermMartian wrote:
Really? I've never actually seen that happen, even with my own programs.
