The first post details how to make a project. This tool can also be used, and I suggest using it if you'll be using Visual Studio (which I suggest using).
Ashbad wrote:
insight -- do I need to download the headers for that somewhere else?
Also, just wondering, can someone explain in detail the process of setting up your own project and how each of the files work?
I believe that I explain creating your own project in the first post. Also, just wondering, can someone explain in detail the process of setting up your own project and how each of the files work?
thanks, Merth and Kerm
One more question -- this isn't explicitly prizm-related, but is an .hpp file a .h file written in C++ or something? I saw that insight and another program used them for include files.
.h and .hpp (and .c and .cc and .cpp) don't mean anything to most compilers. However, they're generally hints to the programmer about what is a C++ source file (and its associated .h file), namely .cpp or .cc with .hpp, and what is a C source file (and its associated header file), namely .c with .h. However, there are plenty of people who ignore this convention and use .cpp/.cc with .h.
Question:
In Ubuntu, I downloaded Wine and followed all of the instructions. The issue is that the .lib file is non-existent when it really is.
'Z:\home\ray\Desktop\CASIO_miniSDK\lib\FX____.lib' doesn't exist.
Ashbad, no problem, that doesn't sounds newbish at all.
Raylin, can you give more detail? Is that the error, including those underscores? When does this happen?
That is the error verbatim. Except the file name is actually fx9860G_library.lib.
Raylin wrote:
The executable issues this.
/me feels like he's pulling teeth. ![Wink](images/smiles/icon_wink.gif)
I followed every step to the letter.
When I press F9, the error occurred.
Lemme try duplicating the project and see what happens.
It's obvious, so I'm sure you checked this already, but did you make sure that that file did indeed get copied over? When I press F9, the error occurred.
Raylin wrote:
Yep. Just double checked.
I don't quite know why this isn't working...
So you did indeed copy "fx9860G_library.lib" from the SDK directory to the /BIN/ folder of the MiniSDK? I don't quite know why this isn't working...
I'm also having problems with this. I'm apparently missing a file called "header/filebios.h" even though I don't use it as an include. Why would this be happening, and how can I fix it?
Cf. my answers to you in the Useful Routines thread, although this is actually a more appropriate thread in which to hold the discussion. -
Ashbad
- Guru-in-Training (Posts: 2497)
- 02 May 2011 02:42:30 pm
- Last edited by Ashbad on 02 May 2011 03:36:15 pm; edited 1 time in total
okay. would you like to see what else needs fixing? Seems as if I beat my old error-record I made with that z80 hello world:
Here is all of the code (the snake char array I shortened for your convience
however, it is made correctly, SC2.5 style from a PNG.
ERRORS GALORE:
http://pastebin.com/FTS5hryK
extern "C" {
#include "stdlib.h"
#include "keyboard.hpp"
#include "keyboard_syscalls.h"
#include "display_syscalls.h"
#include "display_tools.h"
#include "fxCG_display.h"
#include "misc_tools.h"
void G3A_main(void) {
Bdisp_AllCr_VRAM();
memcpy(VRAM,Snakee,(384*216*2));
Bdisp_PutDisp_DD()
char Snakee[165888] = {
0x00,0x00,0x00,0x00,ETC. for ~80000 more character initiations
ERRORS GALORE:
Holy... That's a lot of errors.
Well, your unselected icon is missing a few size bytes, I can tell that :p
» Goto page Previous 1, 2, 3, 4, 5, 6, 7 Next
Page 3 of 7
