Hey, I was playing with some legos yesterday and had the idea of removing the hammer and replacing it with the lego brick remover. We only really need a model, if anyone is up for it. I'm not sure if the ldraw parts library contains a brick remover.
Wouldn't that be a big and unwieldy in the hands of a 1.5 inch figure? And since we have an editor gun, do we really need the hammer at all anymore?
I more or less agree with this, though there's no reason someone couldn't implement a destroy-everything game mode that involved a hammer. I do like the idea of the brick remover, but it doesn't seem properly scaled for gameplay...
The original hammer was actually a mallet, so we could use the real hammer. It should be on LDraw's part list.
- TheStorm
- NOU! (Posts: 2553)
- 06 Mar 2011 09:51:05 pm
- Last edited by TheStorm on 06 Mar 2011 09:55:32 pm; edited 1 time in total
To quickly destroy things
I could see it being used for minecraftesk random levels if we can get the brick count up that high.
Also I'm sure we can come up with a use for the brick remover, maybe a master hand like bad guy or boss for some game mode that a modder may come up with.
"Have a nice day, or not, the choice is yours." Tom Steiner
Actually The Orange Block had a minecraft-like brick mining mechanic with melee weapons before there was even a minecraft.
elfprince13 wrote:
SpaceNinja wrote:
By the way, if we have a hammer, what for is the magic wand then?
Nada.
TheStorm wrote:
elfprince13 wrote:
Nada.
Isn't it like when you're admin you can destroy other's bricks with the hammer?
elfprince13 wrote:
We really shouldn't have separate tools. The hammer should just use proper permissions.
I think that would be both the more elegant and less-confusing option. elfprince13 wrote:
Yeah. Initially, the magic wand had the unique ability to chain-kill bricks, but since TBM's saving system does not record brick connections, it only works on vanilla blockland-style one-time structures, making it rather useless. You could theoretically add this functionality to the hammer along with permissions, assuming you could find a way to check for extended brick connections.
Since I'm implementing iGob-like functionality with LDRAW MPD documents, this could be used to delete all sub-objects from a particular branch of the object tree. Where it could get tricky is multiparenting (having, say, a leg sub-model that you are using for both legs of your mech, and trying to delete a brick from one, but not the other). I could probably give the option to delete from "only this instance" or "all instances" though, and duplicate the submodel before modifying it.
The way the wand worked, if you hit a brick on the ground, and there were no other bricks linking the model with the ground, the whole thing would collapse. I'm not sure if you could do that with TBM models built with totally open positions and rotations however...
We also don't need to blatantly rip-off behavior from other games
» Goto page 1, 2 Next
