I was wondering if there is a way to have a .jar log every file inside it that is uses as it is used. So for example, if you have a .jar that just runs a script to display some image, it would log what it runs until it is exited. I hope this made sense.
This could be what you want. It requires the Java IDE Eclipse.
I have no idea what that was talking about, all I know is it is talking about running a .jar with a different program. :/
comicIDIOT wrote:
Stop double-posting. If you can't edit your posts, delete your old post before you post a new post.
I am too lazy to actually make my own post so instead I quote people and then don't say anything newdragon1414@att.net / Google and Yahoo E-Mail
I would use Java.util.logging in each class, and in a static method, just get whatever logger. Then, you can create another class/program that uses the same logger to display the log. So basically, you would LogManager.getLogger(String name), to get a "LOG". Then, in the program that reads it, add a Handler for it. You would basically have something like this in each class:
And then the reading program:
I hope this works.
static {
Logger logger = LogManager.getLogger("My.Test.Log");
logger.log(Level.ALL,"String here");
logger.addHandler(new Handler()); // technically, you deal with the abstract messages here.
I hope this works.
debugger + tracing + profiler should have you covered
