Does the 1.5 build support hit detection, as in detecting what part of the player's body was hit(head, arm, torso, etc.), or am I going to have to wait for T3D to do my Gabby Giffords shooter? I read something about this in an old player.cs but am not sure if it's been implemented yet.
That's part of the idea, but I'd also like to show how much damage 33 9mm shots could do if that law isn't changed. This wouldn't be possible without semi-accurate hit-detection. Think of it like JFK reloaded, but with more modern events. Speaking of which, being able to trace the shots as they go through people and bounce off scenery and display the forensic results would be sweet too, but I'll settle for a body count and a warning.
Even if I scrap this idea altogether, other deathmatch-style projects would Benefit greatly from hit-detection. I did rudimentary head and groin shot detection in TBM by tracing the height of the projectile relative to the player's location(which is always the base of the feet), but that was dependent on the freakish proportions of the lego minifigure. A human-proportioned player using this system would detect shots that should have whizzed passed the target's head as headshots, and any headshots on people who are wounded on the ground as body shots, grossly detracting from the realism of the project.
I haven't found anything that would support the idea that this feature is by default part of TGE. Did some searching around on GG today, but no dice.
so this isn't used for anything then?
// Damage location details
boxNormalHeadPercentage = 0.83;
boxNormalTorsoPercentage = 0.49;
boxHeadLeftPercentage = 0;
boxHeadRightPercentage = 1;
boxHeadBackPercentage = 0;
boxHeadFrontPercentage = 1;
function ProjectileData::onCollision(%this, %obj, %col, %fade, %pos, %normal)
if ( %col.getClassName() $= "Player" )
%dmglocation = firstWord( %col.getDamageLocation( %pos ) );
if ( %dmglocation $= "head" )
%headshot = true;
%col.damage( %obj, %pos, ( %headshot == true ? %this.directDamage * 1.5 : %this.directDamage ), "Projectile" );
DShiznit wrote:
How does it get the damage location then? Does it use different collision meshes in the model?
Those percentages you posted are the positions if memory serves me right, if true you'll have to tweak em a bit to match the legodude since it's not as big as kork.
I'm not even using the lego dude, but thanks for the info. Perhaps I'll take a look at the demo code, as I think it has working headshot detection...
