I'm unsure of the function of this library. Does it connect to gCnHub, or does it provide a method to communicate with the connected calculator?
_player1537 wrote:
gCn hub, that way you can write computer clients to connect to gCn and play games.
And support any other functions, or offer server services over gCn.
http://img152.imageshack.us/img152/9369/capturevx.png
this is the error I get when I put it into dedugger, I dont know what they mean
- _player1537
- Guru-in-Training (Posts: 2983)
- 29 Jan 2011 03:48:39 pm
- Last edited by _player1537 on 29 Jan 2011 03:50:07 pm; edited 1 time in total
It means: download the source, open the .slu and hit f5
Edit: Hmm, no .slu or whatever it is. In that case it's Chat.cs, I think.
@SirC:
It depends on what you're doing, I suppose, but you'd just have to write some software that interfaces with gCn and offers what you want, and then keep it connected at all times. The whatever client software you have on the calc would connect to gCn using the right hub name and be able to talk to the service.
For example, you could write a file repository that has a bunch of calc software. You set up the server to sit there and wait for a calc to send a "Give me a file listing" or a "Give me file X" packet, then you send back the data to that calc, basically the standard Clent-Server Paradigm. The nice thing about gCn is that it has a pretty simple packet format, and you could easily build your own packet format inside of that.
@ qazz:
That must be a problem with my library. Can you tell me what you're doing before that happens? Does it do that just as you start?
@ qazz:
I open it, press connect, set my name, press the other connect, watch me join SAX via the program, then, it crashes...
thats about it
thats about it
merthsoft wrote:
@SirC:
Indeed. In fact, although the gCnIRCHub, which offers IRC over gCn and is written in Python, could easily have been written using Merth's C# library plugged into some IRC library.
Well in that case, it shall be quite easy to perform the task I wish to perform. I'll inform you all more later.
*Bump* I've managed to get the directory listing of the calc tonight
I think it's about time to break this off into a separate thread. I'll probably do that tomorrow or something.
This is excellent! A superb job, Merth.
The only caveat is that either you are going to need to port part of your work to C++, or I will.
Surely being in C#/.NET is far more useful, given its cross-platform and language-agnostic credentials?
- Site Admin (Posts: 64315)
- 31 Jan 2011 11:52:12 pm
- Last edited by KermMartian on 02 Feb 2011 11:01:27 am; edited 1 time in total
Did Ben just make a grammatical error?! Say it ain't so!
Edit: My humble apologies, apparently my sanity is a thing of history.
But this doesn't require the rest of the things, does it? You just need to tell me what the calc will be sending and what I need to send, and I can do it all in C# with this and my calcnet library.
I suppose, but I wanted a single gcnclient.exe for the Arduino users, the USBHID ($10 bridge) users, and the direct USB users. Do you disagree? Register to Join the Conversation
» Goto page Previous 1, 2, 3, 4 Next
Page 3 of 4
