From the suggestions topic, I'm going to try and create an SE that will display the clock of someone hovers over an icon. After looking over the documentation, I had a couple of questions:
The SDK page says that dModes were stopped between versions 6.2 and 6.7, are they still discontinued?
Err... That's actually the only question I have right now. I'll find more to ask later though
Edit: I knew I would find another question
How do we get the X and Y coordinates of the mouse through the SEMouse section?
They are back as of 6.7; I needed to bring them back so that Jerry (BrandonW's mouse SE) would work.
I believe that dcs7.inc defines the address of MseX and MseY for your reference.
Ah, thanks
Hm, I don't see "MseX" nor "MouseX". Out of curiosity, is the online version up to date? I'm going to check the actual SDK in a minute.
Code: MseY .equ $989E ; [header.asm:149]
MseX .equ $989F ; [header.asm:150]
Also, in response to your earlier CenterText query:
Code: ;centertext - Centers text (horizontally) on the screen and displays
; - Input a = penrow to display at
; - hl -> text
; - Output displays centered text
; - destroys op registers
