Thinking back on the totality of your life, what is the most painful ordeal you've suffered through? This can be physical or emotional; or perhaps a combination of both, if one logically resulted in the other.
Oh, boy. My body has taken its share of abuse... Hands-down, I think the most painful ordeal I've been through was the time I found out I have interstitial cystitis. In short, it's a bladder disease of unknown cause which involves certain food triggers that result in severe pain. My triggers are soy, peanuts and citric acid. Any of these foods damage the lining of my bladder. Depending on the food in question - and the quantity - the pain can range from mild discomfort, (a constant feeling of having a full bladder) to a feeling like urinating shards of broken glass. (this is a very realistic comparison) I was diagnosed because I had just introduced a lot of soy products to my diet at the time, which caused major IS flare-ups. Since I didn't realize this was the culprit at the time, it became impossible to use the bathroom at some point. The pain was so great that I couldn't force myself to go and get it over with. Anytime I tried, I almost lost consciousness from the pain. I had to go to a doctor to try to improvise solutions. Now I take anesthetics whenever I eat certain foods, and there are some foods I have to avoid altogether.
I guess the runner-up would be the time my left ear-drum ruptured. I had a sinus infection that caused so much pressure to build-up in my ear that my ear-drum ultimately ruptured. It was like a sudden explosion, and then blood shot out of the side of my head. Finally, the infection started to drain into my throat, causing another infection that lacerated my esophagus and vocal chords, and left me aphonic for several months. Before I was able to see a doctor, I almost suffocated. I remember lying in bed for hours trying to draw a full breath, and thinking this was how I was going to die. I actually came to peace with the inevitability of it, and was pretty much prepared to die at that point. I was snowed-in at the time it happened. Had I been able to get to a doctor sooner, it probably wouldn't have progressed as much as it did. Still, it wasn't as physically painful as the IS ordeal.
On the bright side, the doctor gave me opiates for the pain. It was quite a euphoric experience at that point!
