Here we shall keep track of what games/programs that utilize xlib to function. Post what games you try and whether they pass or fail. If they fail, Please describe what it is that they do, and post a screen shot if possible.
Games that pass compatibility:
:: Metroid Infinity by bsparks/CDI.
:: Super Mario Smash Dance by DJ Omnimaga.
:: XLib XLib Revolution by DJ Omnimaga
:: Metroid BASIC v1.001 by bsparks/CDI. Repaired by fixing Pic "0" -> Pic0 = Pic "10" bug in real(2)
Games that fail compatibility:
none known
As tifreak said, please test XLib/Celtic programs and report the results in this topic. If the program works well, great, let us know. If it fails, please try to describe the failure symptoms, along with (if possible and necessary) a screenshot.
*bumpity bump* With some help from Iambian, fixed the problem with CDI's Metroid v1.001. Celtic's real(2) clone was improperly changing Pic "0" to Pic "8" = Pic8 instead of Pic "10" = Pic0.
http://www.ticalc.org/archives/files/fileinfo/427/42763.html
Tested that
With Parser hook it only displayed text, no graphics or anything, just text.
Executing it normally (disabling parser hook) causes it to run fine. GASP
EDIT: Tried
http://www.ticalc.org/archives/files/fileinfo/411/41140.html
No.... just no, it is missing all graphics, it does not go past the begining page.... just... no
...it would actually be interesting to write a program that tests compatibility, akin to Acid3...
Rthprog, that would indeed be pretty nifty!
@Qazz, good stuff, I'll check those out as soon as I finish working on solving this issue with FileOpen/FileSaveAs with Anak.
K, this seems to be a pattern with Xlib prgms, all graphics are barely screwed or completely screwed
"all graphics"? By contrast, every single XLib game I've tried with the exception of Metroid v1.001 has looked fine, and I fixed the issues with that game yesterday.
Tested that
Age of Culture v0.89 worked flawlessly for me under Doors CS.
*bump* And I had no problems with the xLib BlokDude game, either. Text and graphics were both fine. :/
This xLib problem is the same issue I have been having with my current Fable: TLC game I'm working on. The text( command erases the graph screen upon it's first encounter. Unfortunately, I had to revert back to the standard xLib and remove DCS7 compatibility...until this is fixed...
Can you send me a sample program with the bug to test?
Is that the same bug as during Reuben Quest: Ev Awakening title screen menu?
It might be; I'm not positive until I see his code. Until you mentioned it, I didn't think it was the same, because yours looked like an Output + image splitscreen issue, and his is Text(). Is yours instead Text(-1 on the graphscreen?
Oh, right, I forgot this part of my game used Horiz mode to have both home screen and graph screen. My bad x.x
It's still possible that it's slightly related, but I think yours may be a different unfortunate interaction of TI-OS flags and modes.
It seems like the code is corrupted, did you try re-sending the program?
As Souvik says, you seem to have a corrupted copy of the program, unfortunately. Perhaps we can ping Nitacku on IRC and get him to take a look.
Yes 2 times, to my calc a few times, and to wabbit a few times as well. it is not corrupted before playing i checked that as well.
