Quick Assembly SDK v2.0
This program takes a high level language of my creation and generates an optimized .asm version for compilation with most z80 compilers. Also it converts monochrome bitmaps to assembly or C files for z80, 68k, or C up to 320x240. The same QASM code can compile flawlessly for Ion (83 and 83+), Crash (82), MirageOS (83+), DoorsCS (83+), and regular 83, 83+, & 86. Some command line skill a prerequisite but very easy with xterm. Tested on Linux Ubuntu 12.04
Mostly, just ironed out the offset errors and removed the TI-85 support.
Monochrome bitmaps can be 1x1 to 320x240 :-)
| Name | Size |
| qasm/QASM.html | 7.7 KB |
| qasm/QASM.html~ | 7.9 KB |
| qasm/compile.bash~ | 0 bytes |
| qasm/good tests/test82.asm | 1.3 KB |
| qasm/good tests/test83.asm | 1.1 KB |
| qasm/good tests/test86.asm | 1.1 KB |
| qasm/good tests/test8X.asm | 1.2 KB |
| qasm/good tests/testDCS.asm | 1.6 KB |
| qasm/good tests/testIon83.asm | 1.2 KB |
| qasm/good tests/testIon8X.asm | 1.3 KB |
| qasm/good tests/testMOS.asm | 1.4 KB |
| qasm/qasm | 43.9 KB |
| qasm/qasm.c | 33.7 KB |
| qasm/qasm.c~ | 33.8 KB |
| qasm/screen.GIF | 1.1 KB |
| qasm/test.bmp | 4.1 KB |
| qasm/test.txt | 439 bytes |
- 35.8 KB
- http://ceme.tech/DL917
- Quick Assembly SDK v2.0 (published 12 years, 8 months ago; 2013-08-12 23:24 UTC)
