CGlock
[Warning: This add-in is obsolete, unsupported, and in rare cases may brick your Prizm. Caveat downloader.] A simple add-in that lets you lock your Prizm. The first time it is run it will ask you for the unlock code, but if you want to set a new code later, press OPTN at the main CGlock screen and then press F4. Full instructions and details in the README file included in the archive.
CGlock.g3a | 102.1 KB |
README.txt | 4.3 KB |
Source/Makefile | 5.2 KB |
Source/Makefile.old | 707 bytes |
Source/calc_locked_msg.png | 2.1 KB |
Source/check_24x19.png | 287 bytes |
Source/denied_32x32.png | 526 bytes |
Source/gimpplan.xcf | 31.0 KB |
Source/gimpsettingsplan.xcf | 19.9 KB |
Source/hold_turn_off_msg.png | 1.9 KB |
Source/icon.xcf | 13.3 KB |
Source/input_help_msg.png | 2.0 KB |
Source/insert_new_unlock_code_msg.png | 2.6 KB |
Source/insert_unlock_code_msg.png | 2.4 KB |
Source/lock_fill_24x32.png | 391 bytes |
Source/lock_stroke_24x32.png | 416 bytes |
Source/mainscreen_msg.png | 4.1 KB |
Source/question_mark_12x24.png | 353 bytes |
Source/selected.bmp | 17.3 KB |
Source/src/CGlock.c | 361.0 KB |
Source/unselected.bmp | 17.3 KB |
Source/wrong_code_msg.png | 1.7 KB |
Source/x_21x21.png | 275 bytes |
- 76.2 KB
- http://ceme.tech/DL723
- CGlock (published 10 years, 4 months ago; 2015-02-06 23:14 UTC)
