CALCnet2.2 SpeedTest 1.0
  3. TI-83 Plus/TI-84 Plus Assembly Programs
You can use SpeedTest 1.0 to benchmark the maximum speed transmission
capabilities of CALCnet 2.2 between two linked calculators. SpeedTest
supports two types of tests. The first, unidirectional, sets one
calculator as the transmitter and one as the receiver. The transmitter
then repeatedly sends frames to the receiver, and both count the number
of bytes transferred. The second, bidirectional, lets the two
calculators take turns being the sender and receiver. The sender will
send a frame to the receiver, and when the receiver successfully reads
the frame, it will send a frame back to the first calculator. Both
calculators count the number of bytes sent and received. You can read more about CALCnet2.2 at http://www.cemetech.net/projects/item.php?id=33 .
Screenshot #4607 Screenshot #4608
readme.txt 3.5 KB
speedtst.8xp 1.0 KB
speedtst.asm 11.2 KB
5.3 KB
13 years ago
  1. CALCnet2.2 SpeedTest 1.0 (published 13 years ago; 2010-12-06 17:06 UTC)
