The Token Quest
  2. Cemetech contest entries
  3. #27: The Dungeon Master
The Token Quest
A cyberpunk-themed RPG and hacking simulation developed for TI-84 Plus CE and TI-83 Premium CE graphing calculators.
Developed by Ubuntu_is_life
Plot
The game takes place inside a corrupted operating system where rogue processes and memory leaks threaten to cause a system-wide crash. You play as a programmer navigating through different memory sectors to purge corrupted nodes, bypass firewalls, and collect data fragments. Your ultimate goal is to complete the "Initial Compile" to restore the system and find the Original Token.
There are 4 areas, in which you can go and explorate : in it, the combat is all automatic, when an enemy is nearby enough, you attacks it , and depending of your competences, the enemy sustains more or less damage, knock-back, etc
The areas contains items, that you can pick up to obtain a temporary boost (health gain, DPS boost, bag of Bytes, range...)
By pressing [enter], it displays a map of the level, showing your position and items positions. At first the map displays only a 3x3 area around player's position.
To finish a level, you needs to complete a full "purge" (purge at 100%) : enemies spawn continuously, and then when you killed 99 of them, the boss of that area spawns : it is bigger, has more health, is less affected by knock-back and it does more damage than normal enemies. If you manages to kill him, he restores a shard of The Original Token. There are 4 shards: If , For , Goto and End. Each shard corresponds to an area, and restoring the first shard unlocks the second area, and so on...
When you exit a game (finishing or not the level), you receives Bytes (money of the game) so you can upgrade your abilities in the Forge (Attack speed, Raw damage, Max health, Health regeneration and Protection).
Achievement system :
As you play, you'll unlock achievements, and thus you'll unlock new mechanics and parts of the game.
By the main menu, you can access different sub-menus :
- Forge menu to upgrade your abilities (see above)
- Parameters menu :
- Erase save data (clears all data, except language)
- Tweak luminosity (with the arrows)
- Change language (between english and french)
- Replay introduction (the introduction is played the first time you open up the game, then it doesn't show again, except here. The first time you launch the game, it begins by requesting which language to choose)
- Achievements menu
- Statistics menu (kill number, best progress during a game, number of game played, total Bytes collected)
- Help menu
- Credits menu
Prerequisites and Installation
- To run The Token Quest, you need a TI-84 Plus CE or TI-83 Premium CE with The Celtic CE library installed, see at : https://bit.ly/CelticCE
- Transfer the 3 game files (TOKENQST.8xp, TOKBATTL.8xp and TILES.8xp) to your calculator.
- Launch TOKENQST.8xp to start the game
Credits :
The Token Quest, a game by Ubuntu_is_life
Made for the Cemetech Contest #27
Graphics engine : Celtic CE by Roccolox & TIny_Hacker
Screenshot #11024
The Token Quest/TILES.8xp 41.3 KB
The Token Quest/TOKBATTL.8xp 12.7 KB
The Token Quest/TOKENQST.8xp 21.2 KB
The Token Quest/readme.md 3.0 KB
The Token Quest/screenshot.png 837.6 KB
625.8 KB
Install the Celtic CE library to run this program
Development topic of this game
https://www.cemetech.net/forum/viewtopic.php?t=21184
10/10 (2 votes)
Can you PLEASE PLEASE PLEASE make an asm version please bro.
Pretty good game.
Though I could just stand in one place and let the enemies come to me. But collecting items is an incentive to move
The forge system is nice (upgrading DPS is really good).
Bosses are nice, but they do the same damage as normal enemies
Also hate that you took all my bytes away just to remain level 1 at regeneration.
Also kind of broken after Level 2, but I think that is my fault
  1. The Token Quest (published 2 months, 3 weeks ago; 2026-06-18 12:04 UTC)
