EXACT3
  3. Casio Prizm (fx-CG) Math Programs
This program gives you the exact values for expressions like, 4(√19-3), 4(√192+16)and also similar expressions with third- and fourth roots. I know that the CG 50 has a program built in for this, but it isn’t always working, and you can’t use it in retrospect. The program strives to reduce the expression as much as possible. There is also an input for the precision to search with. Which can be rather tricky to decide. If you remember one or two digits though, for example 16 in the second expression, it is safe to choose it, since 4 is bigger than 1. Always choose a positive integer, because the program only manages expressions with integers that gives real numbers. So, you must not input an expression like: 7(√-14-8). It won’t work. 328 bytes.
EXACT3.g3m 384 bytes
EXACT3.rtf 1.4 KB
2.4 KB
Anders
  1. EXACT3 (published 9 months ago; 2024-10-11 15:25 UTC)
  2. EXACT3 (published 9 months ago; 2024-10-11 00:43 UTC)
