- TI-84 Plus CE Programs
- TI-84 Plus CE Assembly Math Programs
Hi, This is TicoIn! The first Calculator based crypto currency.
To use it, just send the .8xp file over, and it will make the appvar on the app, so you don't have to worry bout it.
The way that the coin works, is that it sends the first coin to a cache, and then after that first cache, it then needs to pay the miner, so it gets the id for that payment and formulates a hash for that id. That hash is then sent into the pool and then that hash is mined. That cycle then infietly repeats.
The Hash is created by taking the id(numbloc) and doing the following math: ((((numbloc*numbloc)*999)-51)*3)+1
If you want to take out the coin, you can transfer the app var "money" to your computer, but don't expect to do anything crazy, becasuse the blocks conflict as soon as two people mine it, or in other words, two people will win the same block, which means that it doesn't have enough complexity to be worth anything.
In conclusion, if you want to waste energy with your ti84, this is the #1 way to do so :)
TicoIn/readme.md | 997 bytes |
TicoIn/TICN.8xp | 7.3 KB |
- 8.2 KB
- http://ceme.tech/DL2538
- TicoIn (published 7 months, 2 weeks ago; 2024-10-06 14:31 UTC)
